Question about Dometic WA3210 Compact Refrigerator
Camper fridge will not cool down(unsure of model)
I have a dometic 2 cu ft fridge for my palomino pop up camper. Last year, I was preparing for a camping trip, I started the propane pilot to begin cooling the fridge for the trip, then went into my house. 2 minutes later I came back to find black smoke coming from the outside compartment, after disassembly, I found a spider nest in the propane assembly causing the flame to "back up" and melt a wire. I cleared the nest, replaced the wire, and restarted the pilot only to find that the fridge would not cool. I removed the fridge from the camper, and hooked it up to 110v supply, allowed it to sit for 24+ hrs and it still would not cool, the camper is three years old, therefore, the fridge is out of warranty. I am fairly handy with mechanical fixes if pointed in the right direction, any suggestions?
  • Anonymous Mar 27, 2014
    can stack distributor be in wrong place?
  • 159 Answers
Ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
Posted on May 15, 2009
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
My beverage cooler MCBC58DST wont stay cool after it reaches target temp.
Throw it out and get another model from another company. Their units are junk!
They last a year, at best. Them and Magic Chef are one and the same...so you may have to bite the bullet and get a real unit.
Good luck. I speak from experience...I've had four now. Complete junk!!
Nov 23, 2014 | Vissani 5.8 cu. ft. Wine and Beverage...
Puma trailer, Why is 2yr old Fridge not covered under warranty?
Contact the manufacturer of the fridge, perhaps their owner relations dept can assist you. If it's Dometic, go to : (www.dometicusa.com ) Have your model and serial number ready.
May 06, 2014 | Palomino RVs
I have a Dometic fridge model number RM2612 in a camper that i just purchased used and the fridge isn't cooling. The freezer section seems to be okay. The metal plate in the freezer gets cold but
Make sure it is level, has proper airflow out through top vent. Also check baffle, or stack where flame sits under and blow it out good with compressed air to make sure it's clean. If you smell a hint or strong smell of ammonia, shut it off, it has a leak in cooling unit. If all ok in that area, shut it off, disconnect and plug propane line, disconnect power and remove the fridge. Turn the fridge upside down for a day or 2, then re-install and let it sit 24 hrs before turning it back on. Quite often that will take care of any blockage in flow of cooling liquid, and get things back to normal if cooling unit is still good.
May 22, 2012 | Dometic RM2620 Refrigerator
Hello, my dometic camper fridge runs great on gas but just clicks when i switch it to electric...??? any advice thanks Stephanie
The mains heater has a different thermostat. Check power to the heater, and the back coil is getting warm
Apr 27, 2012 | Dometic RM2652 Refrigerator
My side by side 23.6 cu. ft. no frost refrigerator is not freezing and the refrigerator is not getting cold enough. There's frost on the back wall inside freezer. It's a GE TFX24VR. What can I
usually that means your fridge thermostat is being blocked by items in your fridge, telling the cooling system to shut down. If your fridge and freezer are packed, the fridge might protect itself by shutting down the cooling system. Happened to us last Thanksgiving.
Mar 07, 2012 | GE Refrigerators
Whirlpool 10 cu ft fridge, freezing cans of pop at rear center of unit and spraying interior. Have had the fridge over a year with no problems until the last couple of weeks.
Turn the cold control down. If you have already have the cold control turned down then you will need to replace the cold control/thermostat with a new one.
Aug 03, 2011 | Whirlpool Refrigerators
I have a dometic rm 2652 rv frig.. it is 4 years old and is not cooling. you can feel heat in the tube on both propane and electric but no cooling. can you be of any help on what I can do to fix this...
Inside your fridge there are fins, on the far right there is a plastic piece that slides up and down, this will adjust your temp. OR it can be your thermister. At the back of your fridge access from out side your camper there is a black box with lots of wires going to it , pop cover unplug wire P2 (your thermister) Then you will need an Ohm meter buy at any auto parts store, at the back of the plug test buy putting the red in one prong and black in the other you should get a reading of 6 Ohms now the plastic piece in the fridge pop it off the fin and remove the little wire with little tip and place it in a cup of ice and little water wait for 5-10 mins. and you should get a reading of 15 Ohms. And one other thing it might be a bad ground. Good luck.
Sep 18, 2010 | Dometic RM2652 Refrigerator
Have dometic three way fridge in pop up truck camper that is cooling but not cold enough stays at about 50 degrees answers???
Find thermistor/thermostat that is usually attached by plastic holder at back on one of the fins in fridge compartment. Pull it off, and move it over to left 2 fins, then give 24-48 hrs and see if any change.
Jun 16, 2010 | Dometic RM2652 Refrigerator
Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Jul 06, 2009 | Dometic RM2620 Refrigerator
Dometic WA3210 Compact Refrigerator Logo
1,327 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
