welcome to USA computer repair help. what computer is this? name and model. what DEVICE is failing (DEVISE) em208vid (what is this?) it is not a computer it is in fact a. Ematic EM208VID 8 GB Purple Flash Portable Media Player my guess, is the battery is bad, replace it. 99% of the time BATTERY IS BAD. if 6.3 bytes is real and not 6MB the the Flash memory is full. erase it or buy a bigger one. 8GB flash , new. it had. bad battery if 100% dead. #1 cause of all portable devices is that.
Hi. What is needed is a codec pack upgrade. Here is Imation's support page. They also have a phone number you can call: https://support.imation.com/app/home Good Luck
you must see the picture attached. Use digital camera the LED must be TURN ON, if doesnot follow this a) open r.control clean the keypads for dirty, oxide, corrosion, bad contacts use contacts cleaner b) clean the contacts battery, and test the wires for loose, or bad solder, resolder , replace a new batteries. c) resolder any colder joint, with color slight yellow( this produce NOT circulationg energy). and try again. God bless you
Exact issue that I have. I tested the phone with a multi
meter and it shows only 0.02v (ac) while plugged in with not battery on. The battery
also shows 0.02v. The phone is not charging correctly causing the red light. I don't
know why or how this happened. The battery should be 3.4v and should charge at
that same voltage but it's not!
Hi, maybe the TV controller board is blocked, you can reset it, by disconnecting power cable from outlet for about 5 minutes, if that doesn't work, possibly and internal board or component must be repaired of replaced, in such case it's better to contact an authorized Samsung service center or technician to check your TV.
HI,
Hi this player is multi region code free .
There is no code region for this appliance.
Please check other possibilities that cause your player malfunction.
Regards
