Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Refrigerator stoped cooling
Out of the blue it stoped cooling, same with the bottom freezer, the fans work at the top and the bottom. Every 5 minutes I can hear a "click" and what seems to be the motor start working, within seconds the same click sounds and the motor stops, maybe the thermostat?
the cooling controls (buttons) are at the same levels as always and I have changed them to a higher cooling settings but nothing.
Any help would be apreciated.
  • 6,784 Answers
Ok, if the unit compressor will not run and just clicks on and then off, this will confirm a low charge state ad you will need to recharge this unit. the refrigerant level is low.
Purchasing a recharge kit and recharging the system will fix this issue.
Posted on May 15, 2009
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
it should not be the compressor as the bottom is only not cooling.
Jun 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Maytag MTF1895AEW Not Cooling
Sounds to me the compressor start relay=> 63001003 Overload=> 63001004 and Run Capacitor=> 63001005
needs replaced, the clicking noise indicates that that is the problem, Sea Breeze
Feb 16, 2012 | Maytag Refrigerators
FRIDGE AND FREEZER DO NOT COOL. FAN AND COMPRESSOR ARE RUNNING AND AIR IS FLOWING THREW THE VENTS BUT A WIERD NOISE APPEARS EVERY 2-3 MINUTES LIKE THE COMPRESSOR WANTS TO START BUT IS RUNNING STILL. ...
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
also are the coils clean?
Feb 26, 2011 | Maytag MBB1956GES Bottom Freezer...
Refrig/bottom freezer not cooling, fan running, lights running, controls working fine, every 5 minutes a humming, then a clicking....cleaned condensor fans and cleaned condensor coils by vacuuming My...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 30, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
My refrigerator stoped cooling and freezing. The lights and the fan come on, but will not cool...
The first thing I would do is remove the cover on the back of the fridge and check if the compressor is running. If it's not, then it could be the start device. Remove the power from the fridge, pull out the start device from the compressor and shake it. If you can hear something inside is moving, replace the start device.but if otherwise then,
Your defrost timer located inside the control panel is bad OR the defrost thermostat located on a freezer coil is bad.
Get down low and look up at the bottom of the control panel.
You will see a small round hole. Onside the hole is the defrost timer advance knob.
Use a flat blade screwdriver and SLOWLY turh the slotted knod clockwise until the refrigerator clicks off.
Wait a few minutes then open the freezer door and listen for a sizzling sound from the freezer compartment.
If you do hear a sizzling sound that would be the defrost heater melting ice.
If you do not hear a sizzling sound,unplug the refrigerator and remove the rear freezer panel to expose the cooling coil.
Clipped to the coil will be the defrost thermostat. It will need replacing.
If you do hear the sizzling sound the defrost timer will need replacing.
Good luck and hope this will work
Jul 30, 2010 | Maytag Refrigerators
Top Freezer won't freeze--blows 50 Degrees constantly!!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check the fans especially the condenser fan. the noise you hear is probably the klixon cycling because the compressor is hot. You can put a fan blowing on the condenser coil and see if this helps.
Good Luck,
Gilsh
Nov 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Frig. and Freezer not cooling. Clicking sounds heard every 2 mins
sure sounds as if it is def a compressor overheating, now that the compressoe will be cooled it should work , but your right damage may be already done, the good news if any is that you should be covered under 5yr manufactures warr for compressor
Dec 22, 2008 | Maytag MTF2155GRW Top Freezer Refrigerator
It is the compressor that has failed. The hum is it trying to start and the following click is the overload protector opening. What is the temperature where the refrigerator is located? Allow the compressor to cool down before trying to restart it. If it still does not restart after it has cooled off it is done.
May 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
GE model GTST2BPLWW
they all have fans the freezer does all the cooling for the whole unit there is nothing in the bottom unit that cools the freezer fan blowes air from the freezer down to the bottom and draws air to the top if you dont hear the freezer fan running and there would be no doubt in your mind if it was then pull the fan cover and see why and let my know hold my rating till we are done please
Feb 11, 2008 | GE (GTS16BCS) Top Freezer Refrigerator
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
156 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
