Question about Mitsubishi WS-55807 TV
Mitsubishi tv picture is scratchy when first turn on, for about the first 5 min. then 0k. TV about 10 years old.
  • Anonymous Jan 08, 2008
    I have a mitsubishi ws55807 tv and when I turn it on I get a dark screen, and static. The audio is fine. Right now this lasts for about one minute and then everything is fine. I had the signal board worked on by a qualified technician and everything was fine for a couple of weeks,but slowly returned to the original problem. Help! Chris
I NEED SCHEMATIC
Posted on Jan 01, 2008
  • LENHAT456A Jan 01, 2008
    i have a tv have problem : no video but it have audio
No picture have sound timer light blinks .when you turn TV on lamp light come on. Goes off. Tv have sound for 10 min TV cut off type 62" Mitsubishi dlp
How old is your TV set ? if you have not replaced the lamp in 2-3 years that is most likely the problem and need to replace that part.
This lamps now run from $40.00 - $90.00 depending on quality.
Jul 30, 2013 | Televison & Video
KP53S35 when tv turned on picture was
You TV has a bad CRT, a red CRT by the sounds of it. This TV is rather old, perhaps 11-13 years of age? Your TV has given you many years of service and I do applaud you for the care you have given it and the TV for it’s reliable in your home. The trouble you face with a rear projection CRT set of this age is that you can’t just change 1 CRT tube and expect it to be reliable and produce a good picture. All 3 tubes should be replaced, as they have all aged the same. The lives of these tubes are only about 7 years. A tube is not any easy or inexpensive repair on any RPJ TV. When you are faced with the cost of 3 tubes, which may not even be available in the market place… You should consider retiring this old friend and keep the manufacture in mind as you make a new purchase.
Mar 14, 2010 | Televison & Video
My Sylvania flat screen sound keeps going off
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/ The most probable cause is with its audio output IC itself; overheats.
May 11, 2017 | Sylvania Televison & Video
Horizontal lines in the picture.
Give it time to warm up like another 10 to 15 mins i find put a tv guide channel on the screen stays pretty much the same picture, then leave the TV on" i use a 4 hour rule if i dont view in 4 hours or more i will close tv power
Oct 07, 2009 | Mitsubishi VS-60705 60" Rear Projection...
OVERHEATED?
yes open it up get dust out run small fans in nit see how long it stays on
Sep 15, 2008 | RCA HD52W56 52" Rear Projection HDTV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Big Screen TV not working
Check your video input cable or replace, maybe it is damage if not Video chip problem etc
Dec 16, 2007 | Mitsubishi WS-55513 55" Rear Projection...
My Sony tv CRT
If it's between 5-10 secs, that's normal. You will turn the tv on and hear a loud (buzz/hum) that is the picture tube firing up, once it's fired up, it has a few more seconds until your picture comes up fully. That is about 5-10 secs from pushing the power button.
If it's taking longer than that, your picture tube may be going out.
I had a 36XBR250 and it took about 10 secs to fire up and show a picture, and it was 5 1/2 years old.
Nov 25, 2007 | Televison & Video
Toshiba 36zp38b picture problems
With it only being about 3 years old, I would suspect bad solder connections rather than defective components like Capacitors. You may get the symptoms to come and go by slapping the side of the set or jaring it slightly which would prove the bad connection thesis. It is not a permanent cure however and you can make it worse if you keep doing that. A solder repair shouldn't run over $225 in my opinion.
Mar 11, 2007 | Toshiba 36AF61 36" TV
Mitsubishi WS-55807 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
