Question about Gateway Computers & Internet
Computer won't boot properly
The PC acted up after I tried running a video from a newly purchased external hard drive (Fantom Drives ''Green Drive'' 1 TB). When I ran the video the computer basically froze so I manually restarted it. Sometimes it will only go to the screen that ''Windows is starting up'' and do nothing more. Other times it will get to the desktop but then stop working when I try to access a program. I ran it in Safe mode which didn't improve the problem.
Is there something through BIOs I need to do or through Safe mode?
  • jack_hurley May 15, 2009
    Is this from the original xp repair cd that came with the system or through Accessories?
    If the former, I likely lost the cd a while ago but will check. It seems to be working now but I am wondering if it is only a matter of time before another reboot issue
    Thank you for your help
  • 35 Answers
Hi
Had the same problem many moons ago all i did was to run a repair on my o/s from my xp cd sorted out the problem, hope tthis works for u 2
SlitWrists
Posted on May 15, 2009
I have a Fantom Titanium II 500 GB external hard drive. It is not being recognized on any of my Windows 7 computers (64 bit Gateway and 32 bit Lenovo). The light on the drive is a constant blue. I tried...
1. if you don't eject the eternal drive properly it could cause the controller board inside the case to fail.
.2. USB drives are to be eject by the windows feature never disconnect while drive is in the port without using the ejection feature.
3. check the drive in another port to see if it can be seen in the computer list.
if not you may a defective usb controller in the case. the drive can be remove and installed into a new case. The drive may not have been damaged.
4. A new case can be purchased at the local computer store.
Apr 24, 2011 | Fantom Titanium Hard Drive
I had a problem with my pc it cant power on and only green light in the board i see. any advise please
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Mar 21, 2011 | Computers & Internet
When i turn on my fantom green drive the green light keeps flashing
If the light turns on (mine was blue) but the drive is not recognized on your computer desktop that most likely means the drive does not have enough power. This happened to me too, and I took it to a computer expert and he said the drive was not even spinning. So it was either the external power source that broke or the internal power source, the power panel that broke. I took it to a batter plus and tested the wattage for the external power source and it was okay so then i took the entire drive apart and disconnected the naked hard drive from the power panel. Then I purchased "SATA to USB" cables (runs around 10-20 bucks) and connected the naked hard drive that way to the computer and it worked. So the problem is basically that the internal power panel is not working, and i had 2 fantom drives that both had this problem and they both worked after i did what i just said.. so I think your drive has the same problem since the light comes on but the drive is not spinning. Take it apart, buy some SATA to USB cables and it should work.
Sep 30, 2010 | Fantom Drives 120 GB Hard Drive
Formatting a Fantom G-Force drive from NTFS to FAT 32
my computer> right click on the terabyte> select format> make sure u change the option of ntfs to fat 32
May 27, 2010 | Fantom G-Force MegaDisk 1.0TB 7200RPM USB...
I have a fantom hi speed usb external hard drive. How do I back up data from my pc onto it?
If you are running windows XP you can go to START, PROGRAMS, ACCESSORIES, BACKUP
Just follow the prompts from there!
Feb 03, 2010 | Fantom Drives 120 GB Hard Drive
Ext 500G Fantom HD turns on but won't boot up.
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the flash drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your flash drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your Hard Drive to be detected automatically.
Kindly keep me posted about the problem
Hope this helps you out.
Nov 19, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
FULL fantom external usb harddrive is not acknowleged after power outage running check disk.
ACS Data Recovery specializes in Fantom hard drives, and can perform successful recoveries on any model Fantom hard drive. If you have a crashed Fantom hard drive, please call us today to get a quote: 1-800-717-8974
unless you fancy trying to connect the drive inside the unit directly to a pc by taking the box a part.
Jul 18, 2008 | Fantom Titanium Hard Drive
Fantom Titanium Hard Drive - 500GB
You can remove the drive from the casing and connect it inside your pc, using IDE cables if its an IDE or a SATA cable, if it comes with one
Dec 26, 2007 | Fantom Titanium Hard Drive
Problem with my PC recognizing my external hard drive
If you know the files are there and the drive cannot be read then there must be a read error, the only other thing to try is a different usb or firewire port as the port itself may not be reading the drive. Try it first by putting in a different port while the pc is on then plugging in and then restarting if the device is not recognised. You may also try the drive in a friends pc to see if it is port trouble and not the drive
Apr 28, 2007 | Fantom Drives 120 GB Hard Drive
Yellow light?
Tre, save early, save often, save many. I have seen, heard and experienced external hard drives failing. It is a good habit to use the "usb device safe removal tool" the green arrow on the task bar. When the device is safely removed, turn it off. When you need the drive again...turn it on save files, safely remove device, turn it off. Sometimes the turning on and off of the computer with the drive hooked up can cause issues over time. Anyway hope that helps. Good Luck. Tim
Mar 14, 2007 | Fantom Titanium Hard Drive
Computers & Internet Logo
43 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
