Question about Goodman GMS90703BXA Heater
Flame sensor hello my problem is the same as others. My heater will ignite but will not stay lit once blower kicks in. Cleaning the flame sensor sounds like a good answer. but where is it located. thanks
  • Anonymous Mar 27, 2014
    Blowers comes on but flame ignites but goes out after a couple seconds. After 3rd try itnshuts off completely.
  • 1,420 Answers
The flame sensor is located in the burner box of this unit. You may have to remove a cover plate to get to it. It will either look like a small probe or small diameter copper pipe (real small).
It will either be close to the pilot or ignitor or aways away where the flame has to travel to it.
A small brush or sand paper can be used to clean it.
If your furnace has more than one burner, while you are inside, clean out the track that allows the flame to travel to each burner. A small can of compressed air works great along with a small wire bruch.
Posted on Oct 16, 2007
My Ruud achhiever 90 starts to fire but as soon as the blower fires the burner goew out. I also noticed that the "igniter" on the end isnt firing. Could that cause the burner to not stay lit when the
There is an ignitor and a flame sensor. If the ignitor does not ignite the gas after a time, it goes out. If the flame sensor does not detect ignition the gas valve closes. When you start it you should see the ignitor come on like a light bulb and glow, then the gas valve opens and you get ignition. Then the flame detector turns on when the ignitor goes out. Flame detectors are like a chrome wire that has one connection to it and it sits part of the way in a burner. They get dirty and corroded. When that happens it shuts down. You can clean the flame detector with steel wool of scotch brite pads. Dont get too carried away doing that though.
Dec 25, 2012 | Heating & Cooling
Glow bar lights up, blower kicks on, air blows then flame starts then goes out then we get 1 green blink which says ignition failure
Dirty flame sonsor.Left side of the burner rack..A steel pin with white porcelin & 1 wire to it.remove the one screw(1/4"hex) holding the bracket and clean/polish the rod part with light sandpaper or steel wool.Re-install and the flame should" Prove" and stay lit.Thanks
Oct 29, 2011 | Goodman GMS90703BXA Heater
Thermostat calls for heat, purge motor turns on, 15 seconds later hot igniter turns on, then gas turns on and burners are lit. Problem is, they only stay lit for 5 seconds then shut off and cycle repeats...
,Hello, Make sure the flame sensor is clean near the burners, The flame sensor is a metal rod that is on the opposite side of the ignitor. To clean the flame sensor you will need some steel wool, turn off power to the furnace and remove the flame sensor and clean it with the steel wool. After cleaning reinstall it and turn power back on to furnace.
Mar 02, 2011 | Goodman Heating & Cooling
Unit seems to ignite then cuts out, then blower comes on. Sometimes goes through that sequence and then no blower, does that 2-3 times then light on thermostat saying heater is on stays on but unit does...
If this has an igniter could be flame sensor. Flame sensor tells gas valve that flame is present or it will kick out. Flame sensor should be small rod connected to one wire, and it is on the flame somewhere sometimes opposite end from igniter If you do have sensor turn power off remove sensor and clean If white film on it. I usually clean it with dollar bill
Jan 21, 2011 | Heating & Cooling
Hi Im having a problem with my furnace. Igniter lights up blower kicks in it ignites for about 10 sec then goes out and blower blows cold air It repeats this process over and over It is now 50 degrees f in...
look for the flame sensor , its a small metal rod in front of one the burners you need to sand it with some sandpaper and it should stay lit. attached is a pic of what it looks like.
Dec 13, 2010 | Goodman Heating & Cooling
My furnace lights but only stays lit couple sec can hear a click then goes out
Sounds like it is not proving flame, to check you need a meter that will read DC microamps. without knowing the brand I can't say what you should be looking for. Trane furnaces need at least 1 DC microamp to prove presence of flame. Usually you will see 2 - 2.6 or so, but it depends on what the manufacturer specs to prove flame. At minimum you can pull the burners out and clean them really good (especially the cross-over wings) because if the flame doesn't roll down to the sensor fast enough during the trial for ignition it will recycle and eventually lockout. If it stays lit longer than 20 sec, it most likely is proving flame and cycling off on high limit because the blower is not coming on. The typical blower on delay is 45 sec from the time flame is proved to when the blower is energized
Nov 02, 2010 | Coleman Heating & Cooling
My suburban RV hot water boiler ignites but won't stay lit. The ignitor keeps clicking
Could be the flame sensor is bad,it looks like a thermocouple scratch it with a knife then try again.
May 16, 2010 | RTO Suburban Rv Water Heater Dsi Gas Valve...
Jandy Lite2 Pool heater will not stay lit after firing.
Look at the sensor that tells unit that everything is lit. There should be some sort of sensor that tells the ECU that the ingnition area is a burn temp. It sounds like the unit can't tell that flame is lit. Hope this helps.
May 17, 2009 | Jandy Laars Lite2 Pool & Spa Heater -...
Goodman GMS90703BXA Heater Logo
134 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
