Question about Refrigerators
Water leaking into refrigerator. No ice machine or external water source attached to refrigera- tor. Whirlpool refrigerator model ET18LKXHW01. Top freezer
  • Refrigerators Master
  • 4,654 Answers
Sound like the drain from the defrost line is blocked allowing the defrost condesate to run down inside the compartment. Here is a link with more of how to fix the problem. Thanks, Sea Breeze
click link below
http://appliancejunk.com/forums/index.php?topic=22.0
Posted on May 16, 2009
Leaking ice maker
I cannot provide information on the particular problem but I suggest you find the model and serial number of your refrigerator and search the Whirlpool website for any service bulletins or recalls. In the meantime keep the water turned off to the refrig. until a repair is identified.
Aug 19, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
I replaced the water filter in my Whirlpool/Roper side-by-side refrigerator. Now ice maker and purified water (on front of door) don't work. No water is getting to the ice maker. Is it a defective water...
1.CAN YOU TELL IF WATER IS GOING TO THE FILTER, FIRST OF ALL.
2.IF WATER IS NOT GOING THREW THEN THERE IS A BLOCKAGE BEFOR THE FILTER
3. IF WATER IS GOING TO THE FILTER { CHECK TO IF THE FILTER IS IN CORRECTLY}
4.IS THE WATER GOING THREW THE FILTER, IF SO THERE IS A PROBLEM WITH THE KINE FROM THE FILTER TO THE LEVER TOR THE WATER TO COME OUT.
5. ALSO CHECK FOR LEAKS GOOD LUCK
Jun 23, 2017 | Whirlpool 21.8 cu. ft. Side-By-Side...
Refrigerator gushing water through ice maker filter
Filters themselves don't usually leak. Check full insertion of filter, cracked filter housing or cracked supply line.
Aug 14, 2009 | Whirlpool Refrigerators
Whirlpool refrigerator leaking from top of unit
Listened to other posts and figured drain plug was clogged. It was with ice. Removed bottom pan and back panel of freezer, removed ice on bottom, put hot water in drain to thaw ice until it flowed into pan underneath fridge. Thanks for the ideas.
Jun 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
May 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Whirlpool ultimate 2 model#lsw9750pw3 ser.ct1941128 leaking in front. appears to leak from a bow with 2 hose connected.
Your water pump is attached to the motor and is probably the source of your water leak.
Replace the pump.
Use the attached video to show how to access the cabinet and pump.
May 03, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool refrigerator leaks
the drain hole at the bottom rear is blocked. a pipe cleaner run down it should clear it out.
Apr 09, 2009 | Whirlpool ET8FTEXM Top Freezer...
Water leaking from freezer down back wall inside fridge
Defrost water from a top freezer models exits the cabinet in the rear. This drain line may be plugged.
May 07, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
254 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
