Question about Acer Aspire 4520-5141 Notebook
Reset LOM password on V120
Hey, I am currently trying to find a way to reset the LOM back to factory defaults on a Sun V120. Currently we are able to remove one of the jumpers and get into the LOM, but it will not let us reset the password for any of the 4 user accounts. Wondering you have any insight. Ideally, I would like to roll this back to factory defaults and start over.
  • 431 Answers
Hi I am Vortash ... try this Remove the memory back up battery a small round penny sized battery in a holder on the circuit leave out for 1/2 hour and then replace this should have wiped the cmos and the bios and enable you to access to bios... hope this helps regards Vortash
Posted on May 15, 2009
I changed the default password, and I forgot it. How can reset the password, without lost the configuration?
There is no way to recover the password unless you reset it to factory defaults. This would mean losing your current configuration. I would try to guess everything you can possibly think of. If you still can't figure it out you need to reset to factory settings. To reset factory settings there is a button on the back of the router that says reset. Hold this down for 30 seconds and everything should be reset.
May 17, 2011 | Zonet (ZSR0104UP) Router
I forget my password , how to reset password ? please help me.
May 17, 2011 | Computers & Internet
I want to change my passport
If you do not currently have the password you can reset the device to the default factory settings by pressing the reset button for determined period of time (usually 7 seconds fro Belkin). The default password should be blank, now you can log into the device using its IP address on a we browser and change the device password under its settings or the wireless password under wireless security.
May 06, 2011 | Belkin F5D8236-4 N WIRELESS ROUTER4PORT...
I forgot my login name and password. How can I reset and start over?
Hey there,
Check this diagram of the back of your router: http://etech.maiila.com/wp-content/uploads/2010/12/Netgear_WNR2000.gif
The small button that's labelled as "1" on the diagram is the reset button. It's quite small, so you'll need to use the tip of a paperclip or ballpoint pen. It's designed to be small so you dont hit it by accident :)
Push down and hold on the button for 5 seconds, and release.
Allow your router to reset and turn back fully back on.
It has now been fully restored to factory defaults, and you can start over.
Hope this helped you out! Feel free to rate me if I did help you :)
Cheers
Mar 08, 2011 | NetGear WNR2000 Wireless Router
How do I change the password or locate the current one?
Try admin with no password.
http://www.default-password.info/d-link/
If that doesn't work you will have to reset the router to factory defaults by holding the reset with a paper clip or something for 10-12 seconds (Beware, this will default the router, you will have to set it back up from scratch)
Dec 22, 2010 | D-Link WBR-1310/RE 54Mbps 802.11g Wireless...
Can not get access to menu ON ROUTER 2800G vigor. Have correct IP address of 192.168.1.2 but page will not load. Will a reset cure the access problem. Router is currently providing internet access
A reset would resolve this isssue but it would be reset to factory defaults, so you would probably have to get in contact with your isp to set the settings back for internet access.
When you type the ip address do you get a user name and password window up or just nothing at all? You try 192.168.1.1. And see what happens.
Feb 04, 2010 | Computers & Internet
I forget my sonicwall admin password how will reset this password
If the SonicWALL's admin password is lost, there is no backdoor or other mechanism to bypass the administrator login. Please note that prefs files do not contain the admin name and password. So if you reset the firmware and import a current prefs file, you can gain access using the default login credentials ('admin' & 'password'). Without a current prefs file, you must reset the firmware and configure from scratch.
For models running SonicOS (Enhanced or Standard), you can reboot to factory defaults. This resets all settings including the admin name, password and LAN IP address. Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login.
For models running Firmware 6.X, you must reset the firmware (wipe and upload using the reset procedure). Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login. The 'Reset to Factory Defaults' button does not reset the admin name, password or LAN IP address for these models
Feb 03, 2010 | SonicWALL PRO 1260 SonicOS Enhanced...
Dont no password
hey of you are just new try to type on the user name "admin" then in the password "admin"
or "administrator" then also in the password "administrator" if you dont change it yet. but if you alrady change it you have to manual reset it it you forgot your password.hope it works.
Oct 25, 2009 | NetGear WGR614 Wireless Router
How to reset VSX 8000 to factory default - Forgot the password
RTFM!!!
section 8, page 4
System -> Diagnostics -> Reset system
you will need serial number for this
good luck.
May 03, 2009 | Polycom (VSX 8000/VORTEX EF2280 ) (Bundle)...
Acer Aspire 4520-5141 Notebook Logo
754 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
