Question about Eureka 5892AVZ Bagless Upright Cyclonic Vacuum
Vacuum bar not rolling
Hi!  I am using my roommate's eureka.  It is gorgeous and fancy so of course I had to go and break it.
I don't know exactly what happened.  I ran over a bookbag strap, heard a "clunk" sound, turned the vacuum off, pulled the strap out, and turned the vacuum back on.  The rolling bar no longer rolls.  I examined this bar.  It had a dryer sheet wrapped around it (not sure where it picked that up or how long it was there).  I pulled and removed the dryer sheet.  The bar still does not roll. There is other debris around it- a couple of hairs- but nothing that would interfere with it rolling.  Vacuum still has suction and all other parts seem to be fine.  Do you know how to remove and clean the roller?  Or should I just give up, fess up to the roommate, and bring it to get serviced somewhere?
Belt is busted . Need new belt . Vac comes with three additional belts. Ask your roomate belts he should have them somewhere.
Posted on Nov 26, 2007
I have a Eureka Altima and not sure how to change the belt?
1) Use handle release to lower handle
flat onto floor
2) Remove 2 screws from the front side of
brush roll cover
3) Lift and remove brush roll cover .
4) Remove brush roll and belt. Thread
new belt around motor shaft and
brush roll
5) Insert left end of brush roll first. Make
sure square on brush roll cap is in
place. Pull right side of brush roll to
stretch belt. Secure right end cap into
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover
8) Replace 2 screws
And you can get the maual here.
Good luck
Sep 27, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
The suction on my eureka optima stopped working but the roller still works, what might i do to fix it?
Hi there. Most suction problems are due to a blockage. Start with the base and look carefully for debris that is stopping air flow. You may have to remove the base plate to get to the problem. I am including a link to the manual for your machine. look on page four so see how to remove the base and check for blocked airways.
Aug 19, 2009 | Eureka 431A Optima Bagless Upright Vacuum
In Carpet setting, the vacuum brush does not spin
I put 3 turns of electrical tape around the area of the beater bar that meets the vacuum belt. This solved the problem short of replacing the beater bar.
Jan 18, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka boss 5893A brush roll does not work
you have to prss the pedal and lean it back the brush roll wil enguage
Jan 11, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Multiple broken belts in months
Either the belt is not tracking straight, the brush roll is bad(check the ends to make sure they turn easily), or the base has warped and the brush roll is not sitting in the proper spot.
Nov 01, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Belts keep breaking
Check the brush roll ends to see if they have melted or frozen. They should turn freely, part #361869-1. Make sure the belt isn't being pinched somewhere.
Apr 15, 2008 | Eureka WhirlWind Litespeed 5844 Upright...
BOSS 5851 Wide Track, 12 Amp
The top comes off to get to the belt and brush roll. Did you check the brush roll to make sure that the ends turn freely, or is one not turning, the belt is a lon life "U" part #61120A. The brush roll is what drives the vacuum, but if brush roll or belt is bad, then it won't drive it.
Feb 03, 2008 | Eureka 5849A Boss Bagless Upright Cyclonic...
Eureka 5892AVZ Bagless Upright Cyclonic Vacuum Logo
Top Eureka Vacuums Experts
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
