Laser will not work on PHD+ dolphin
Everything is set up right with our scanner, but then when we are ready to scan, the laser is not working and will not scan. I can manually type in the barcode # and it works correctly, but we cannot figure out how to get the laser to work
  • 47 Answers
Depending on the operating system, the scanner driver may not be there. If your device is Win CE, there is no scanner driver in the O/S. If it is WinMobile, there is. You may have to have your dealer sell you a utility like DataWedge or ScanWedge - there are others as well. Contact your dealer or the Honeywell Help Desk.
Posted on Nov 04, 2009
Error code 007 340
Hello!
This issue relates to an error with the PHD (Photoconductive) Unit. To resolve this error please try the following steps:
1. Turn the printer off.
2. Wait 10 seconds.
3. Turn the printer on.
4. Determine if the issue still occurs.
5. If 007-340 or 007-341 Restart Printer Error recurs please remove the PHD Unit and remove any packaging.
To Remove PHD Unit:-> Remove the Paper Tray
-> Open the front cover.
-> Put a piece of paper on the transfer belt to protect it from scratches and from light damage. Do not cover the left and right of the belt guards with the paper.
-> Rotate the four stoppers of the PHD counter-clockwise 90 degrees to release the locks
-> Remove the PHD unit toward you by pulling it by the left and right handles.
-> Lift up the PHD unit from the printer. Be careful to avoid scratching the transfer belt.
-> Remove the packing tape by pulling straight out
Reinsert the PHD.
-> Close the front cover.
6. If error recurs with the PHD Unit re-seated please try another PHD from a working 2130CN Laser Printer (if available).
7. If issue recurs after trying another PHD or no PHD Unit is available, please call Dell Technical Support to advise.
Oct 28, 2013 | Office Equipment & Supplies
Follett dolphin phd
So, I had a large scan.log file which I would have lost if I followed the instructions above. Instead hold the shift, on scan and bksp buttons simultaneously. The device will reboot with your file still functional!
Aug 27, 2013 | Computers & Internet
I need solution of scan lock
which Printer do you have ? If samsung multifunctional printer..
Open scanner Glass, see belt are proper insert on Scanner mechanism , If not ? inserting properly.. now u r printer and Scanner is ready to work
Aug 19, 2013 | Samsung SCX-4321 All-In-One Laser Printer
The barcode reader eclipse ms5145 powers on,the laser light blinks and beeps at scan by not scan the barcode
It could be either one of two things, first of all will this unit scan any barcodes, or is it just one particular one it will not scan. If nothing scans and if no special programming was added to the scanner I would consider defaulting the unit back to factory settings. This procedure can be found in the manual that came with the scanner or here is a link http://www.honeywellaidc.com/CatalogDocuments/00-02544%20Rev%20K%202-11.pdf *** If you are going to do this please confirm that no special programming was done to this *** but normally they are ready to scan right out the box. So scan the barcode to "enter/exit configuration" the unit will beep tree times, then scan the "recall defaults" and the unit will beep once. Then scan the "enter/exit configuration" once more. Then try to scan a retail barcode. Hope this helps.
Nov 02, 2012 | Eclipse Metrologic MS5145 Barcode Scanner
Unable to scan a certain barcode, i think it's just a configuration as I'm able to scan some. I know this model works as i already have one that scans OK but was set up before my time in this company. I...
what kind of scanner is it? is it a 2d barcode that you are trying to scan?
Also make sure it isn't a printer issue: ie: barcode is too light.
Does the scanner act like it sees the barcode? beep or any other notification?
Oct 04, 2017 | Dolphin 7600 Barcode Scanner
J4580 OfficeJet All In One Printer Laser: the printers scanner is not working and when i pre...
Just check that can you scan from HP Solution Center, if yes. Then perform the steps given below to resolve the issue.
Open HP solution center:
CLick on settings:
select scan settings from settings.:
A Menu Appears.
select scan to setup:
a new page will appear:
you will see all options on the left side:
select all the options manually and click on the right arrow
to move all the options from left to right side.
after perfoming these steps.
Restart the printer:
and try scanning from printer now.
now will be able to scan from printer itself.
May 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
Laser not working, screen won't show, beeps continuously.
i think i can help u with this, if u unscrew the unit and carefully unhook ur the cables in side then will see two Philips screws, unscrew them and unhook the display cable its on the side
now gently try to take the board out and put it back on then hook the display cable back and screw the board back and for the scanning
unhook and re hook ur scan cable that will make it work,i hope that will solve ur problem
Jun 11, 2009 | HHP Dolphin 9550 Barcode Scanner
The laser is not working on my Follett PHD- Dolphin scanner
You need to do a system hardware reset. Do this by remove battery and find small pin hole just below the battery terminal single pin side. It may be covered over by black sticky pad. Get paper clip wire and put through hole to you feel small click. Hold down for 10 sec and then put battery back in to see the unit run a rebooting procress.
Hope this fix it
Jun 09, 2009 | Computers & Internet
Computers & Internet Logo
328 people viewed this question
David Payne
David Payne
