Question about Brother HL-2040 Laser Printer
Brother HL-2040 Printing With Strange Gray Marks on Back of Paper
About a week ago, my toner light lit up on my Brother HL-2040.  I replaced the toner yesterday with a brand new one, and I followed the supplied instructions exactly as I did it, but when I closed the printer and tried printing something, the page was printed, but the entire sheet was smudged dark gray with toner, front and back.  I did not know what could be causing this, because it's the first time I've replaced the toner since purchasing the printer, so I pulled the toner and drum out again and tilted the toner back and forth some more, thinking that perhaps the toner wasn't spread properly or something, but it still did not work properly.  After that, I took the drum out and wiped the larger shiny roller clean, because it was covered with toner, and I didn't know whether that was normal or not.  When I reassembled everything and tried printing a page, the printed side came out perfect, but the back of the page still had some small light gray smudges on it.  Now, I'm wondering if my drum is in need of replacement, and if so, could it be my fault?  If not, do I need to clean a part of it or something.  I'm quite frustrated with this, because I live at school and in addition to myself, several housemates of mine depend on this printer.  Plus, I don't have the money to buy a new drum.  So, I'm crossing my fingers for some good news.  Thanks in advance for any help.
  • Paul D 86 Oct 20, 2007
    I've actually solved this problem already, but i forgot to update this.  I didn't actually do anything.  I just kept using it, because there was nothing I'd had to print yet that had to be spotless, it was all jsut for personal use.  Gradually, the grey smudges disappeared, and now it works perfectly.  I have no idea why this happened, but I'm not complaining.
    And I guess I forgot to mention it, but it was a genuine Brother toner, brand new in it's original packaging and everything.
    Thanks for your help though.  : )
Sounds to me like the toner - that is the toner cartridge has the wrong toner in it. The drum should be OK - clean it up first and then use a genuine toner cartridge OR you can buy our refill kit on eBay - search for Brother HL2040 - michellem6123
Posted on Oct 20, 2007
All the light flashing
Try this procedure as mentioned.if any mistake in trying the procedure then retry from first step again.so read it carefully and try it. Brother ML-2040 Toner Light Reset
When replacing the toner cartridge in the Brother HL-2040 with a new cartridge (compatible or remanufactured) the user may experience a problem with the toner light staying on, even with the new toner installed. The procedure below has worked for many folks, so give it a shot.
Open the front cover of the Brother HL-2040 and leave open while completing the following steps:
1.) Turn the printer off.
2.) Hold the ‘go’ button while turning the printer on. All panel lights should be on.
3.) Release the ‘go’ button once all lights are off.
4. )Press the ‘go’ button 2 times.
5.) Pause.
6.) Press the ‘go’ button 5 times.
7.) The toner light should be off.
8.) The paper light should be on.
9.) Close cover. The ready light should be the only light on.
Once all steps are successfully completed your “low toner” light should be fixed.
------------- From Brother Service Bulletin
1. Open the Front cover
2. Press and hold the GO button
3. Power ON the printer while continuing to hold the GO button
4. Once the 3 LED’s are lit, release the GO button
5. Press the GO button 2 times. This will cause the LED’s to light solid
6. With the LED’s lit solid, press the GO button 5 times
7. Toner Life End will then reset
8. Close the front cover.
----------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 02, 2010 | Brother HL-2040 Laser Printer
Brother 2040 yellow toner light on & won't print. Toner just replaced 8 weeks ago. Printer purchased 6 months ago.
You have a one year warranty with Brother if you need repair. You might shake the toner, or put a small electrical tape over the little round windows on the toner cart. to use the rest of the toner, and press the go button 3 times to print the report that tells you how many prints you've made, you could just be out of toner again...
Feb 03, 2010 | Brother HL-2040 Laser Printer
Brother HL-2040 toner led stays on, won't print
There is a window on each end of the toner cartridge that you can cover with electrical tape and keep printing, it shines a light thru and when the toner is too low it says it's empty. The weight can be misleading.
Sep 02, 2009 | Brother HL-2040 Laser Printer
Please describe your Brother HL-2040 Laser Printer problem
Yep this will always happen if your just using a replacement toner. They will be depleted faster compared to the original Brother toner.
Make sure you replace your toner with the original Brother toner.
Aug 24, 2009 | Brother HL-2040 Laser Printer
Drum light HL-2040 Brother
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
On older models
  2. Remove the drum and toner
  3. Press the Go buttom button until all lights are lit, (they come on one at a time) then release it.
Oct 14, 2008 | Brother HL-2040 Laser Printer
DRUM LIGHT KEEP FLASHING
Take the drum out and wrap it up to keep the light out of it.  Check the contacts inside the printer and make sure there is nothing broken on them.  If there is toner on them, try to clean them off.
Oct 06, 2008 | Brother HL-2040 Laser Printer
I have a brother HL 2040 laser printer. The toner and drum light were lit, so I replaced both the drum and the toner cartridge, but the toner light remains on. I have tried everything, but the toner...
Two things I could suggest you check. First, make sure you have removed all packing from the drum and toner. Sometimes there is a plastic strip on the toner that has to be removed before installation. Also, make sure you are using a Brother brand toner. Some generic brands do not replace the chip in the cartridge and they will not work,
Sep 19, 2008 | Office Equipment & Supplies
REPLACE DRUM BEFORE TONER'S OUT?!
hmmm...and there is no functionality? I recommend a new set of drivers first from www.brother.com
http://tinyurl.com/6qcpgy
Aug 19, 2008 | Brother HL-2040 Laser Printer
BROTHER Hl 2040 PRINTER WON'T PRING
I got exactly the same problem and the "reset" didn't do anything. I fixed it by putting a piece of duck tape on magic eye on the cartridge.
Fallow those step to do the same thing as me:
  1. Open the front panel.
  2. Remove the toner and the drum
  3. Remove the toner FROM the drum
  4. On each side of the toner, there should be a little glass. Put the piece of duck tape on one of them. I put mine on the right side.
  5. Put everything back in.
  6. Turn on your printer if it's not already.
  7. Now, the low toner light should be gone and the green light should be on.
Now, you can really empty your cartridge.
Apr 06, 2008 | Brother HL-2040 Laser Printer
HL-2040 CHANGE TONER
Reset the drum counter by opening the front panel, then hold down the power button for about 5seconds until ALL the leds are on. Then realease the button and close the front panel. Your coutner will be resetted.
Dec 22, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
710 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
