SOURCE: nissan murano 2005 sl keyless entry remote programing
Close all vehicle doors, LOCK doors using drivers side switch.
Insert key all the way into the ignition, (do not turn) remove key.
Repeat this step 5 times. (6 total)
Hazards should flash to indicate program mode.
Press any button on transmitter to be programmed, hazards should flash to indicate successfull program.
*For additional remotes, cycle drivers door lock UNLOCK, LOCK, press
any button on remote, hazards should flash. Repeat step as necessary.
Ignition ON, (engine off) ignition OFF, UNLOCK using drivers side switch, test remotes.
Source
SOURCE: Is it hard to replace the front wheel bearing hub
Its a big pain. The hub is rusted on tight and has to be beaten off with a mini sledge. Go to your local AP store and look it up in a repair manual to see what you are in for.
