Question about Whirlpool Washing Machines
Whirlpool washer-will not spin and pump out the water in the rins
Will not spin and pump out the water in the rinse cycle. Timer will buzz at the rinse
  • lsbrmb May 17, 2009
    Thanks for your help. It was the lid switch.
    Thanks again
    Genius:
  • 3,422 Answers
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • Ifthe motor is running, your washer probably has a frozen pump pulley ora broken pump belt. To check the pulley, remove the pump from thewasher and try to rotate the pulley manually. If it doesn't turnfreely--if it's frozen or stiff--replace it. If the pump belt is brokenor looks quite worn, replace it--but be sure to check the pump pulleybefore you change the belt.
  • If the motor isn'trunning, the lid switch may be defective. If so, the washing machinecan't spin and may not function at all. The switch is inside thewashing machine main housing near the door frame. Often you have toraise or open the top or front of the washing machine to get to theswitch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • Thelid switch may be defective. If it is, the washing machine doesn'tspin. The switch is inside the washing machine main housing near thedoor frame. Often you have to raise or open the top or front of thewashing machine to get to the switch. If it's defective, you need toreplace it.
  • The motor coupler may be broken. ManyWhirlpool®-manufactured washers use a small, relatively inexpensivemotor coupling. It's plastic and rubber and is mounted to the shaft ofthe motor on one side, and to the transmission on the other. Over time,the coupler wears out and fails. You may need to replace it.
  • Abelt may be broken. Many washing machines have one or two belts. If abelt is broken or badly worn, you need to replace it with a genuinebelt from the manufacturer. (Some washing machine belts are designedwith special characteristics not found in automotive belts.)
  • Theclutch may be worn. If your washer is a GE, it may use a clutch to comeup to the proper spin speed. As the clutch wears out, it may preventthe unit from spinning well or at all. If the clutch is worn, you needto replace it. For this job, you probably want to hire a qualifiedappliance repair technician.
  • The drive motor may bedefective. Many washer brands use a reversing motor. For agitation themotor runs in one direction, for spinning and draining, the other. It'spossible for a motor to burn out in one direction and continue tooperate in the other. If this happens, you need to replace the entiremotor.
  • The transmission may not be shifting properly.Older washers produced by Whirlpool® have a transmission with anelectro-mechanical shifter. If the shifter becomes even partiallydefective, the unit may drain the water but not spin. This is a complexsystem, if your washer has a shifter problem, you may want to hire aqualified appliance repair technician to repair it.
  • Thespin bearing or basket drive may be worn or seized. These componentsallow the inner tub to spin freely inside the outer tub. When this isthe problem, you usually hear a loud sound during the spin cycle. Calla qualified appliance repair technician.
It spins only with the lid closed Forsafety, washing machines are made so that they spin only with the lidclosed. The lid switch prevents the spinning action when the lid is up.
Posted on May 15, 2009
I just replaced the drain pump and don't think that's the problem. it pumps just fine, it just doesn't stop pumping and move on to the next cycle, which would be rinse or spin.
some machines use a rinse spin cycle in conjunction so that the fresh water is introduced and spun out through the clothes to remove the suds completely in which case the pump will be working all the time to pump out the dirty water.. If the machine will not move on to the next cycle check out the timer cycle switch
Aug 16, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer won't go into rinse cycle
same problem. anyone has a solution? checked the lid switch already, it seems to be intact.
Jun 02, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
Kenmore model # 110.244222300, Won't automatically complete wash
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Following is a Whirlpool / Kenmore service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Initial thoughts are that the Timer is worn / broken.
Here is a description of how to gain access to the console on these washers where you may be able to test the timer. (See the Whirlpool service manual for testing)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Jan 19, 2010 | Kenmore Washing Machines
Kenmore washer doesn't drain
This is likely a pressure switch issue.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
Whirlpool ingis washer will not engage rinse cycle
make shure the cold water is on and also if it worked before then it cold be two parts 1 the timer is bad or 2 the water inlet valve
Jan 17, 2009 | Whirlpool Inglis IP4400 Washer
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Will only work on cycle, will not agitate in the other cycles
    Thanks for your question You say it works on one cycle but not the other lets sat you start a regular wash ,the washer should fill ,wash for the minutes you have set, pump out the water #spin , Stop fills & rinse stop pump out water &spin If you try a delicate cycle and it does not do what it did on regular cycle . You have a timer problem . Thanks for your question hope i helped you solve it . THE APPLIANCE DOC
    Sep 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washer will not drain after wash cycle or the spin cycle
    check to see if your pump is slightly plugged with a sock or ?
    Your top loader should pump out in about a minute and a half when totally full of water.
    Aug 11, 2008 | Whirlpool GSC9455 Top Load Washer
    Stops on rinse cycle
    I had this exact same problem. Check and see if the screws to the door hinges are tight and if any are missing. I had one screw missing and it would not allow the door to be level and thus not be able to push the switch all the way down. This tells the washer the door is closed and if it is not closed it wont continue with the rinse cycle.
    Sep 15, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
    Washing Machines Logo
    121 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
