Question about Hitachi 53UDX10B 53" Rear Projection Television
Continued from no picture no sound just clicking
My tv has an odd clicking noise coming from the inside of the tv... no picture no sound but the power light blinks and main board in the back of the tv makes a clicking sound with 2 green lights flashing simultaneously....
  • Anonymous May 15, 2009
    what sites do i go to to get parts for this tv??
  • 6,784 Answers
HI, this is total power supply failure. you and a dual power supply unit that, universally, powers all devices directly. there are no ballast in this set so, you will have to replace the Power controls and the fly-back transformers as well. this will fix this unit.
Posted on May 15, 2009
  • Hitachi Master
  • 19,396 Answers
The TV is on protect mode. The clicking sound is the protection switch that keep turning the TV off to prevent further damage, this happens when a fault had been detected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Panasonic 42 Plasma TV no sound out of TV except a continuous thumping noise
where is the noise coming, from the speaker of the tv or it was coming from inside?.
Oct 16, 2012 | Televison & Video
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Freezer works, refrigerator doesn't, motor is making an odd noise
frost free refrigerators consists of -
1)Heater
2)Thermostat(bimetal)
3)timer
heater and bimetal are in freezer section. First check heater. Give it direct power supply. If it heats up,its OK. Then check bimetal. Immerse it in Ice. check continuity using a continuity tester. If its showing continuity its OK too.
change timer if both heater and bimetal are OK.
Aug 08, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No sound no picture just clicking
TRY CHANGING JACKS,,TRY NEW INPUTS CHANNELS
May 15, 2009 | Hitachi 53UDX10B 53" Rear Projection...
52" plasma tv - turns on - and I hear something reset inside
i hear a clicking noise- the clicking noise is most likely you ballast trying to power the lamp, but failing. this may indicate a defective ballast if you have recenty purchased a new lamp.I recomend you have your lamp tested to help narrow down the cause of the defect. It's highly unlikely for a new lamp to be dead on arrival
Dec 04, 2008 | Dell Televison & Video
TV has no picture, shut off in the middle of a show.
Greetings!
There's a part inside of your tv that over heat, when a minute comes it stop because of the heat. Better check with a tv technician or repair man before the damage became worse.
Thanks.
Nov 13, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Hitachi 61UWX10B 61 in | TV will not turn on after reset | any reset button inside the TV ?
My Hitachi was doing the same thing. The culprit is a bad or intermittent 5V relay on the power supply board.
Jan 30, 2008 | Hitachi 61UWX10B 61" Rear Projection...
TV wont power on, clicking noise and flashing standby led
Sounds pretty bad to me, I had a computer monitor that did a similar thing when plugged in after blowing, it's not a good thing. I didn't even bother to mess with it. You may have to replace the whole power board or at least have a whole handful of pieces to re-solder. It most likely isn't worth it unless your other tv's are under 30" and you don't have a lot of money ;)
- Dave
Dec 28, 2007 | JVC AV-32D305 32" TV
Akai pdp4298 42 in. plasma
The clicking sound is the relay switch on the power board, it could be the power board or the logic board
Sep 03, 2006 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Hitachi 53UDX10B 53" Rear Projection Television Logo
263 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
