Question about SanDisk 4GB microSD High Capacity Memory Card
Only 56 kb memory??
I got this 4gb memory card for my fone, and when i formatted it on the fone, everything got deleted. when i put it back in the computer to add the files back on, it said that there wasnt enough memory. so i checked the properties and it showed that i only had 56kbs of total memory
    Sergeant:
  • 322 Answers
Try formatting it again.
Posted on May 15, 2009
The 4gb Micro SD card is not working. First I formatted it with my phone then I put it in my computer and a picture on it and safely removed it from my computer and put it back into my phone. It showed the...
ok the first thing to do is find out is , is it the phone or the memory card, so try another memory card. with a bit of luck it will be the card that is unstable. if its not the try updating the the firmware on your phone but do it using the pc suite that maches your phone and backup your entire phone contacts pics etc to your computer. now dowload and install the update usually the pc suite will do this for you. i hope that helps.
Jan 12, 2011 | PNY 4GB microSD High Capacity Mobile Media...
How do i format my sandisk 8gb m2 memory card to work with my sony ericsson w395as it doesnt seem 2 work when its in the fone ive tried formating it on my pc but must be different settings for the fone
hi are you formatting it as NTFS? windows xp, vista and 7 format using the NTFS format, try formatting it in fat, or fat32 this could be the reason it is not working....hope this helps
Mar 18, 2010 | SanDisk 4GB Memory Stick Micro M2 Memory...
When trying to send texts from my nokia E63 I get the repeated message Memory full close some applications then try again. Everything is closed and I have deleted everything off my phone!!
I realize that you stated, " I have deleted everything off my phone".
This includes both incoming and out going messages, texts, voicemail, etc? Any pix take up a bit of space too.
I'm just exploring the possibilities.
Best regards,
Mike
Feb 02, 2010 | Nokia E63 Cell Phone
4gb memory card full,need to delete some songs,can i remove one by one,if not how can i free up some space on my memory card
dear if ur fone has not this function to delete one by one so get a card reader and put ur card in it and plug with ur computer and delete ur data as u want..
Jan 10, 2010 | Nokia 5530 XpressMusic Smartphone
No Phone Memory........?
formatt the memory card first....check if its ok.....then update ur firmware if some problem persists
Sep 27, 2009 | Nokia N95 Cellular Phone
My memory stick memory problem
I am not real familiar with this type card, do you know if you can format it like any other card? Sense you have already deleted everything on it( because formatting would delete) try putting you card back into your computer, to to my computer and find where it is located( which port) right click and see if it gives you an option to format, if so, try formatting it and it should bring it back to the state as if you never put anything on it. It is always good too format any memory stick ever so often.
Hope this helps.
Mar 28, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
My fone shows the msg that memory full delete some data...
Solution:
1.Move your images & Videos from Phone Memory to Memory Card..
2.Install Applications in Memory Card Only..
3.if this issue still persists use this reset code
*#7370#
Feb 12, 2009 | Nokia N73 Cellular Phone
My n73 phone starts with installation and says application not supported everytime.
just update ur fone firmware OR hard format ur n73... by following method:
(note : b4 u do any of the above solution remove the password of memory card and also take the backup of ur memory card through Nokia pc suite not by using cardreaders....)
hard format :
remove memory card
switch off the fone
now press call key(green) + 3 + * key
keep on pressing all three keys and switch on the fone ... dont release the keys untill the fone boots on....
the fone settings will be restored to its default... also all d security codes of fone will be retored to defaults....
now ur problem is solved .... put ur memory card back.... n if it still asks for memory card unlock password ... then jus format it .....through fone..... it wont ask again.....
regards
Bhumit
Feb 03, 2009 | Nokia N73 Cellular Phone
SanDisk 4GB microSD High Capacity Memory Card Logo
49 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
