Question about Honeywell Programmable Thermostat Heater
How to remove thermostat cover to replace
How do you remove thermostat cover to replace batteries?
Not sure if it needs batteries....I have manual digital Honeywell thermostat & there is no display...does not read room temperature & does not turn A/C on. Thanks
  • 116 Answers
The cover pulls off if it has a green screen then most likely takes batteries if does not light up then no batteries with a small piece of insulated wire jump from green to red if indoor fan does not come on then transformer bad
Posted on May 15, 2009
The digits are not showing and I have changed the batteries
Remove the cover to ensure the batteries were installed correctly. If they were, make sure none of the thermostat pins are bent a little cause mis- alignment with the pin-holes in the subbase. When you determine all is good, reinstall the stat to the base and make sure it is snapped securely in place.
Jan 01, 2015 | Honeywell Electronic Programmable...
Replaced amp now the honeywell just flashes and the boiler is switched off
If the power to the boiler is off, and you have a power stealing thermostat (tstat with a common), there may be battery backup. In which case, the thermostat is flashing because it is on battery backup. Not sure what you mean by replaced amp now.
Dec 02, 2013 | Honeywell Programmable Thermostat Heater
My Honeywell thermostat keeps flashing the battery icon even after I changed the batteries. It will not kick on my heater why?
The replacement batteries may have been installed incorrectly or the replacement batteries may be defective
Feb 07, 2013 | Honeywell Rth110b Horizontal Digital...
Honeywell thermostat is locked in the off position
sounds like keypad is programmed in lock position read manual for set up to activate keypad again.
Nov 25, 2012 | Honeywell Programmable Thermostat Heater
How can I unlock this th
Remove the thermostat from its base and replace the batteries. To remove the thermostat, grasp it at the edges and pull toward you. The batteries are on the back of the thermostat housing.
Read more: How do I Unlock the Digital Display on a Honeywell RTH8500 Thermostat? ' eHow.com http://www.ehow.com/how_7267447_do-display-honeywell-rth8500-thermostat_.html#ixzz17KTxLwBU
Dec 05, 2010 | Honeywell Heating & Cooling
Cant take off cover to replace battery from my honywell thermostat
Here is a tip that tells you how to get a manual for most any Honeywell product online...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Nov 26, 2010 | Honeywell Programmable Thermostat Heater
Honeywell digital thermostat went blank, ac unit wont come on, its an 8400c, no breakers tripped
This thermostat has batteries. Try replacing the batteries. You may have to reprogram and make sure it is on.
Jul 18, 2010 | Honeywell Programmable Thermostat Heater
I have a very old manual Chronotherm thermostat.
No. The clock is just the set back timer. Pull the battery and use the stat manually.
Jan 26, 2010 | Honeywell Electronic Programmable...
The battery in our Honeywell ST6400C programmer needs replacing as it no longer gives us any back-up; what is the battery, please? Mark Houston mark.houston@asfriend.co.uk
Hi shastalaker
Thanks for the info but how to get the front cover off. Two screws underneath allow the whole unit to be removed but then - nothing. There are two plastic tabs but they do not release anything as they are at one end. The other end remains firmly fixed.
Any thoughts
BigAl
Jan 18, 2010 | Honeywell Programmable Thermostat Heater
Thermostat not working
Chances are that the fuse in the furnace blew. Remove the inspection cover on the furnace and look for a 3 amp fuse either in-line of the wiring or on the control board. Also check the circuit breaker box.
Nov 20, 2008 | Heating & Cooling
Heating & Cooling Logo
3,430 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
