Question about NetGear DG834G Router
Power light flashing green
The power light on my wireless router is flashing green with the i light
The green power light is flashing green with the orange tick next to it and i cant get any wireless internet through it what do i do please help me
Posted on Mar 06, 2010
    Scholar:
  • 58 Answers
Try to reset the router to its factory settings
To restore the factory default configuration settings press both the Wireless button and WPS button on the side of the modem router for 5 seconds.
This should resolve the issue.
Posted on May 18, 2009
5 Suggested Answers
SOURCE: Hi i'm using the eircom
connect kaisa karnga ptcl ma eircom ko
Posted on Feb 02, 2011
Ryd66
  • 65 Answers
SOURCE: Wireless printer stopped printing-wireless router light flashing
Restart your Printer so that it can Look for the Connection again, if you havent done this already.
If this doesnt assist in the problem, please give me the complete Model Number for your printer so i can find the solution
Posted on Jan 16, 2009
  • 84 Answers
SOURCE: Netopia 3347 wireless Router will not work at all.
your router has a volt/amperage ranting ok. check the down side of the router to behold this rating. Something like 12V direct 0.5A. This means you should test and determine your router's adapter power output. If your voltage reading falls within this range: 11 - 14V then its ok, otherwise try another. I cannot overrule the logic board as a possible problem if your adapter gives out the right voltage. In this case, you should contact the vendor. Good luck
Posted on Apr 30, 2009
  • 425 Answers
SOURCE: My ZyXEL p660 router after
You will find ADMINISTRATION tab in the upper right hand corner.
click on the administration tab. just below the administration tab you will find firmware upgrade sub tab. Click on Firmware upgrade.
Now on this window you will find browse option. click on the browse button and select the firmware file that you have downloaded on the computer. after selecting the proper file click Upgrade. The upgrade process will start.
It may take 2 to 5 minutes.
once you upgrade the firmware of the router, unplug the power cable of the router , wait for 5 seconds and plug it back in.
For Netgear router
# Click Maintenance > Router Upgrade
# Click Browse and find the file you just downloaded.
# Click Upload. Do not interrupt the upgrade while the router does this step.
For Belkin router
Open a web browser on the computer.
In the address bar of the web browser, type http://192.168.2.1 and press Enter on your keyboard.
Click Login in the upper right-hand corner of the page.
The router does not ship with a password, so just click Submit.
Click on "Firmware Update" toward the bottom of the left-hand menu.
For D-link Router
Open the web interface of the router.
Go to TOOLS
Under tools you will find FIRMWARE.
Posted on Jan 20, 2011
WHAT LIGHTS ON LINKSYS ARE SUPPOSED TO BE BLINKING
Note that incoming traffic will cause the WAN (or Internet) light to blink even if it is 'probe' traffic trying to break in to your network. Such traffic is to be expected and is the reason you have firewall functionality in your gateway router.
On the inside, there is a bit of traffic on any LAN when the computers are turned on. Messages generated by the router itself are used to find computers and printers for a lot of different legitimate reasons.
Feb 25, 2013 | Linksys Wireless-G WRT54G Router
On my motorola wireless router my wireless light is flashing gren and orange
Orange means it's updating. Power, broadband, and service should be solid green. The others are normal when they flash.
Jan 26, 2013 | Motorola Computers & Internet
Power Problem with 2Wire 2701HG-B
Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
Nov 22, 2012 | 2wire (2701HG-B) Wireless Router
Power light keeps flashing
Normally power light on router is stable solid Green! If you notice the power light is flashing its better to use surge protector! Also try to power off once and wait for a minute or two and power on again. Its always better to use electricity surge protector for all computer equipment!
Oct 02, 2011 | Linksys Wireless-G WRT54G Router
I restet my linsky wireless adapter and all i get is a flashing blue power light
The flashing blue light is absolutely normal!!! Please follow these steps to configure your computers to your wireless router
Here are the recommended steps to connect to a wireless base router 1. Check and remove power from both your router and the DSL ROUTER/CABLE ROUTER MODEM 2. Wait one complete minute until applying power to modem then wait one minute before applying power to wireless router. 3. Ensure you have green lights across both devices, specifically, the recieved and sent lights. These same lights will tend to blink rapidly when there is active data, at times this will still blink, and a DNS error will prevent you from connecting to the internet. If this is the case, call your ISP Internet service provider 4. Check your authentication Security key on your router first, then check all your wireless devices to ensure they are on the same network name, key, and channel with the same type of encryption as the router 5. Start one device at a time and check for connectivity, if your still experiencing a problem, check the settings on all your wireless adapters, device drivers, internet browser settings, firewalls and proceed. 6. still have problems, connect a rj45 cable from the router directly to your computer to at least see if your wireless settings are bad or if the router may be bad. 7. Contact your ISP to determine if your receiving singal 8. Avoid using a splitter or parital power backup for yours routers 9. Still having problems, change your wireless router only after your ISP changes their faulty modem 10.Attempt the same process when setting up your new wireless router and or modem
Jan 20, 2011 | Linksys E3000 Wireless Router
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
I have a green flashing light on my adapter
well this can be caused by many problems the green light means that the wireless card is working properly but you should check to make sure that when you try to connect that you are on the right channel by default many routers broad cast on channel 6, 10, or 11 if this dose not fix your problem i would suggest resetting your wireless router and reconfiguring it as it may be a configuration error on your router.
I hope this helped.
Thank you,
Norse
Jul 02, 2010 | Microsoft Wireless Network Adapter Xbox...
My linksys wrt160n wireless router light is blinking
Welcome to FixYa
Indication of Router Lights:
  • Power light blinks. If LAN or WAN cable is plugged in, their respective lights will flash on activity.
  • Power light turns off for several seconds.
  • All lights, except power light, turn on and then off.
  • Power light blinks slowly, then faster, and WLAN light will turn on.
  • Once Power light and WLAN light are on solid, the router is fully rebooted.
A working router should show solid green power light. upgrade the firmware of the router.
If this Helped you-Rate me..Thanks for Using FixYa
Jun 30, 2010 | Linksys WRT160N Wireless Router
Wirless router not working
it seems to be a problem with your ISP.May try these steps.
1. disconnect the router from the computer and the modem.
2. now connect the Ethernet cable to the modem & to the computer and see if that works.
else contact your isp.
for more help.
moz-screenshot.pnghttp://www.ikarmatech.com
Sep 08, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
NetGear DG834G Router Logo
4,965 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
