Whirlpool washer-- Will not spin and pump out the water in the rinse cycle. Timer makes a clicking noise at rinse
  • lsbrmb May 15, 2009
    Serial # Clo612337
    Model #LSQ8520JQ1
    thanks
  • 460 Answers
To better assist you I need the serial # .
Thank you for trust fixya.com
Posted on May 15, 2009
  • VIRGINIA MARTINEZ
    VIRGINIA MARTINEZ May 18, 2009
    please check the following
    http://www.youtube.com/watch?v=SSM-2qCC3...
    DONT BUY ANYTHING just check all the information that works proparly,
    How to check? I can help you on that as well.
    Get your own volt/ohm meter and take the guesswork out of repair jobs. 18-ranges for all appliance diagnoses! Calibrate your oven temperature
    Hope this fix your problem
    Was this helpful?
I have a kenmore heavy duty, series 70,# 82872120.. It makes a humming noise and will not complete the rinse cycle or the spin cycle.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82872120
If it goes through the agitate cycle, the motor and transmission are probably OK.
If it goes through the initial drain / spin cycles after the first agitate cycle, the Lid Switch is also OK.
The humming could likely be the timer motor. Try to manually move the timer to the rinse cycle. If the washer responds, the problem points to the timer itself.
See the sub component section on the Sears site for the Console.
The "Alt" part numbers are Whirlpool parts that can likely be purchased from a variety of on line or local parts stores.
Sep 26, 2009 | Kenmore Washing Machines
Won't pump out water
Loaded in truck hauled to repair shop.
May 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Whirlpool ingis washer will not engage rinse cycle
make shure the cold water is on and also if it worked before then it cold be two parts 1 the timer is bad or 2 the water inlet valve
Jan 17, 2009 | Whirlpool Inglis IP4400 Washer
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Whirlpool washer fills up; makes LOUD whine/click metal noise
    sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
    Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washer will not drain after wash cycle or the spin cycle
    check to see if your pump is slightly plugged with a sock or ?
    Your top loader should pump out in about a minute and a half when totally full of water.
    Aug 11, 2008 | Whirlpool GSC9455 Top Load Washer
    Whirlpool Washer won't drain or spin
    check the lid switch operation,not sure what the noise could be maybe somthing stuck in the pump? hope ths helps unless the contacts in the timer are faulty i have opened up a few timers and fixed the contacts short term.
    Mar 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washing Machines Logo
    144 people viewed this question
    Top Washing Machines Experts
