Question about Toro Lawn Mower With Toro Power Tools
Toro lawnmower starts then cuts off. It appears to be leaking fu
Mower starts easily, but cuts off in a few seconds. It appears to have a fuel leak, but I can't tell from where. RAW
  • 246 Answers
Hello:
>>From your Description it Sounds like the Carburetor Requires Soaking and Cleaning.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 15, 2009
    Sniper:
  • 57 Answers
If there is a fuel leak causing this problem it could be from the line going to the carburetor or the float bowl. If no leak is present there, could be flooding or a sticking needle in the carburetor allowing fuel to enter constantly.
Toro personal pace mower will not stay started?
If ir starts and runs for only a few seconds it's a dirty carb/bad gas. Drain the fuel system and use FRESH gas; change out your fuel supply monthly to avoid "phase separation" issues. If it runs for several minutes and then dies it is possibly a sticking valve. Do a compression check cold and after it stalls to confirm. Hope this helps
Mar 08, 2015 | Toro 20372 Recycler Personal Pace...
Why lawnmower cut off after it start
Make sure the fuel filler cap breather hole is clear if its blocked it will create a vacuum in the tank which prevents the fuel flowing forward. also check out the kinks below
Lawn Mower Troubleshooting Guide Engine
Small Engine Repair Help
May 01, 2014 | Toro Lawn Boy Self Propelled CARB Walk...
Gas leaking from muffler
Blown engine. Replace engine.
Jun 17, 2012 | Toro Power Lawn Mower
Toro leaking gas through air filter
The inlet needle in the carb is leaking, it may be the activating arm has stuck, remove the float bowl and gently work the float up and down a few times, make sure the needle is moving. Failing that replace the needle valve.
Apr 13, 2012 | Toro Power Lawn Mower
The motor on my lawn mower starts easily and runs smoothly but after a few seconds it starts to hunt. The plug is sooty indicating a rich mixture but their isn't any mixture adjustment. After cleaning...
This is usually caused by either a fuel float that is heavy due to taking on fuel where there is supposed to be an air cavity or.
There is debris in the float needle seat allowing excess fuel to over-fill the float bowl. The float needle has a rubber tip that seats against a tiny fat rubber washer called the seat. If there is debris in between the seat and the needle tip the fuel will NOT shut off causing the symptom you descibed.
If you provide a model number I will look up the inexpensive repair parts that will correct this symptom and provide you with a parts source.
Thanks for choosing FixYa,
Kelly
Aug 03, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Lawn mower ran out of gas, after refilling it will start, run for a few seconds and cuts off. There is no primer button for this model.
It would be best to take this machine into a dealer like www.arcolawn.com and have the thermostat checked out. There were some early autochoke thermostats that would stick and cause problems.Best wishesJoewww.barter-joes.com
May 18, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
My 22" cut toro lawnmower with its 190cc Briggs & Stratton motor with automatic choke starts easily when cold and runs well. When you turn it off to empty the grass clippings bag, it will not restart...
You may want to check valve clearance, sounds borderline. You should have 11/1000s on the exhaust valve.The exhaust is usually the culprit, since it runs hotter.
Oct 05, 2010 | Toro Lawn Mower With Toro Power Tools
Toro lawn mower
ethaanol in fuel...happens when gas sits too long...especially in a gas can in the garage
Apr 10, 2010 | Toro Lawn Mower With Toro Power Tools
My Toro self perpelled lawn mower starts then conks out.
It sounds like your fuel system is plugged up (or water in the carb) First i would make sure there is good fuel supply to the carb, then if so & not running, I would remove the carb and clean as it appears that it is running properly otherwise. Also check your air cleaner element as it may be totally plugged up.. Hope this helps you, Rick
Apr 26, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Toro Lawn Mower With Toro Power Tools Logo
1,599 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
