Question about Maytag PYE2300AY Electric Dryer
Maytag dryer put new timer and door switch on still won't start it does nothing please help
  • gummy bear Nov 18, 2007
    Dryer will not turn on when you press the "Start" button.
    Checked AC line coming into the dryer & checked okay - has power;
    Checked switch on front door - checked okay;
    Checked power going to thermostat - has power going out to the timer, but when I press the timer button, it will not start.
    Could it be that the "Timer" is bad?
The dr. you are correct!!! My thermal fuse was blown. How weird, I was for sure it was the door switch since I figured it controlled the light and it wasn't coming on. Thank You!!!
Posted on Dec 10, 2007
  • 447 Answers
The thermal fuse is blown its mounted on the heater with the two smaller white wires. Check the vent for restrictions (since overheating is what caused it to fail) Was the dryer taking long time to dry before it stopped?? If so there is a definate vent restriction. Part number LA-1053 comes with new high temp thermostat too (recommended).
Posted on Oct 16, 2007
Dryer wont start
You need to have someone check it.
It could be anything from the switch on the door latch to a bad timer...
Feb 23, 2014 | Maytag Dryers
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
I have a MEDC400VWG drier.Woked fine yesterday. Put clothes in it today. Pushed start button. nothing happened. Smelled somthing getting hot. opened drier. Heating coils lit up. (with door open). Turned...
Sounds as if the motor centrifugal switch is stuck. Check to see if lint built up around switch or centrifugal mechanism on motor shaft. Rap switch with the handle of a screw driver hard but don't break it .
Nov 01, 2010 | Maytag PYE3300 Dryer
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Maytag performa dryer quit working
Check your breaker first and then the wiring. Check power coming from the timer next. With a load and resistance that you had, you could have tripped one of the breakers.Since you have bypassed the thermal fuse, it probably is the timer switch.
Jan 26, 2009 | Maytag PYE2300AY Electric Dryer
Dryer knob sticks in one spot- won't move
 Door switch / Door switch actuator leverThe dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Oct 25, 2008 | Maytag Clothes Dryer Almond Timer Knob...
Maytag Dryer
are you sure the door is completely close?
if the door is not closing the door switch, nothing will happen when you press the start button.
Sep 17, 2008 | Dryers
Problem With Maytag Dryer(PYE2300AYW)
you check the igninter on the burner . does it glow red when started then go off . or nothing at all . it has to glow red for any gas to come out to start the heat to dry your clothes .???
Jul 31, 2008 | Dryers
Mdg7400aw natural gas
Jan 14, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag PYE2300AY Electric Dryer Logo
82 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
