Question about Kenmore Dehumidifiers
Kenmore dehumidifier 580.5370 runs without water collection
Kenmore dehumidifier 580.5370 runs but doesn't collect water after being off during winter. unable to locate product manual.
SOURCE: Kenmore 580-51650000 dehumidifier
It is more than likely the compressor is not running, only the fan.
It seams that the humidity sensor is flaky on these units. You can,
operate the unit, by opening up the dehumidifier and unplug the sensor from the main board. The unit will cycle on and off and remove the water from the air.....good luck
Posted on Apr 21, 2008
  • 225 Answers
SOURCE: Dehumidifier Does Not Collect Water
A dehumidifier is just a refrigerating machine with it's shirt hanging out and there is not much in the way of serviceable parts inside.
If the compressor runs - the throbbing sound - and it doesn't collect water then either the intake filter screen is totally clogged with fluff or the compressor has leaked it's gas away, in which case it might run continuously and get hot to no good effect.
If it doesn't run then it may be that the motor capacitor has failed, but that can soon lead to the compressor motor cooking itself; leaving you with an expensive doorstop.
The one thing you might get checked is the "bucket full" switch. There will be a floating part on the bucket which rises up when the bucket fills and eventually makes contact with another part which is connected to a small switch. If that switch has failed you might be lucky and get an inexpensive repair job done.
If these suggestions do help you solve the problem, please give my reply a suitable rating. If they do not, please add a comment with more details so I can try to help you further.
Cheers, D
Posted on Jul 01, 2008
  • 225 Answers
SOURCE: kenmore dehumidifier runs but won't collect water
If you haven't done so already, try removing and cleaning the inlet filter screen which is almost certainly just behing the inlet grille. It may slide upwards out of the casing or downwards unto the bucket area. If this is blocked with fluff then no moist air will get to the cold pipes, so little or no water will be extracted. There's also a chance that the humidity sensor is clogged with fluff, so fooling the system into thinking the room is pretty dry, in which case the compressor will probably not run.
A running compressor can usually be detected as a deep throbbing from the machine. If it is running, but not cooling the pipes behind the intake grille, then you may have lost the refrigerant from the system via a leak. If the air coming out of the machine is warm (caused by the compressor running) but there is no water produced this may be the cause.
Explore along these lines and let me know what you find.
Cheers, D
Posted on Jul 31, 2008
SOURCE: Dehumidifier does not collect water.
My unit does not collect water any more. It was fine until I lent it to my brother in law and it was returned damaged. Do you know how to fix this
Posted on Mar 28, 2009
SOURCE: Kenmore 580-52650100 65 pts./24 hour
Humidifier is fairly old. I put it on the curb for garbage pickup.
Posted on Apr 29, 2009
Kenmore dehumidifier compressor on but doesn't collect water
clean the condenser in the front or the filter if it has one. no air flow to cool it down will result in overheating and no condensation collection across the evaporator coil.
May 09, 2012 | Kenmore Dehumidifiers
Dehumidifier does not collect moisture. cleaned the filter and still doesn't work. fan works fine.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 22, 2011 | Kenmore Dehumidifiers
My dehumidifier runs, but doesn't collect water...then shuts off
heatman101
Jun 06, 2011 | Kenmore Dehumidifiers
My kenmore dehumidifier doesn't collect any water even if it's been on for hours
heatman101
Oct 01, 2010 | Kenmore Dehumidifiers
Our 50 pint 54501 Kenmore dehumidifier runs but there is no water coming out. We have mold collecting on some items in basement
There can be many reasons why a dehumidifier willnot work or collect water.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 11, 2010 | Kenmore 54501 Dehumidifier
I have 2 kenmore 70 pint dehumidifiers. Neither one is collecting water in the pan when running (therefore neither is running). Is there a reset button?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
Feb 17, 2010 | Kenmore 54701 Dehumidifier
Kenmore 54501 dehumidifier runs but does not collect water
heatman101
Jan 10, 2010 | Kenmore 54501 Dehumidifier
Our Kenmore dehumidifier (Model 580.53650200)runs but no water collects in the reservoir bucket. What could be wrong?
heatman101
Sep 18, 2009 | Kenmore 5365 Dehumidifier
I have a kenmore dehumidifier model 53701 and it has been working fine, but now no water is collected even though its running. what gives?
heatman101
Jul 14, 2009 | Kenmore 53701 Dehumidifier
Kenmore 54501 Dehumidifier Problem
Normal 0 When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
Jul 17, 2008 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
94 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
