Question about Dryers
I have a Kenmore electric dryer and it is giving me intermittent heating....every 30 seconds or so, it only blows cold air, then hot, then cold, intermittently. I replaced 2 parts from repairclinic.com - the #2893 and the #940740. What else can I do? The model # is 110.72822101.
    President:
  • 1,136 Answers
Hi, check the venting to the outside and make sure it is clean all the way out.
Hope this helps. If I can help further, please let me know.
Thanks
Vic
Posted on May 15, 2009
Blowing cold air only. no hot air
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 21, 2010 | Kenmore 64672 Electric Dryer
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
OUR KENMORE DRYER BLOWS OUT COLD AIR
It's most likely a thermal fuse if it's a gas dryer. very easy to install. If your dryer is electric, it's either the thermal cut-off or the heating element itself. If you need help with anything, please feel free to e-mail me. good luck :)
Jul 06, 2009 | Kenmore Dryers
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Dryer will run for a second and sound three beeps and stops.
Sounds like the door switch has gone bad., but your description is confusing.
First, it takes a few minutes for you to feel the air blowing hot, particularly when the dryer is in a cold garage. The heating elements have to heat up the mass of the metal, and any clothes in the dryer.
The timer design is such that it can not speed up (the motor inside wont start running faster, due to it's electrical design.).
I am suspect that the door switch has failed for some reason, because reading between the lines, I think you are saying when you release the Start button, the dryer quits operating. If the door switch is bad, then it will cause that condition to happen.
Jan 18, 2009 | Kenmore 62802 Electric Dryer
Dryer blows cold air but no heat
The heating element is in the back of the dryer. Sometimes there is a small access panel that will allow you to check the terminals to the heating element. You will need an ohm meter or multimeter to check.
Jan 02, 2009 | Kenmore 62802 Electric Dryer
Delayed or intermittent heat
after checking the heater core hoses they were both hot I went in to look at the blend door and noticed it wasn't moving on hot or cold so I simply disconnected the lincage and moved to hot and its working ok. but its not completely repaired
Oct 27, 2008 | 2003 Jeep Liberty
No heat
vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Sep 22, 2008 | Kenmore 64982 Electric Dryer
Blows fuse for heat after about 30 minutes
yes , occassionally though it will run for full cycle ....but not very often
Sep 06, 2008 | Kenmore 73952 Gas Dryer
KENMORE DRYER
Electric or gas?
Sep 13, 2007 | Dryers
Dryers Logo
59 people viewed this question
Top Dryers Experts
