Question about Nikon COOLPIX S60 Digital Camera
Cant find format option to use memory card on CoolpixS60
When I insert my SD memory card my Nikon Coolpix camera doesn't recognize that the card was added. I've heard to put the camera in "camera mode" and go to "menu" and find "format" and this will solve my problem. I can't find the format option on my camera at all. Whats wrong?
    Genius:
  • 1,234 Answers
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    Help me import from nikon cool pix s210 to Wlndows Live Photo Gallery 2011....laptop not recognizing camera
    The best way to transfer pictures from a camera with an SD memory card is to do it outside the camera. If your computer does not have an SD card reader built in, you can buy an external USB card reader for $20 or less on E-bay, Amazon, etc. Remove the memory card from the camera and insert it in the card reader. Your computer will treat the card reader and SD card just like it treats an external hard drive. Either drag-n-drop or copy and paste your pictures from the SD card file to a file on your hard drive. If after you have copied and backed up your files you want to reformat your SD card, replace it in the camera and format it in the camera, not in the computer. SD cards formatted in a computer will often not work in your camera because of slight differences in the formatting.
    Jul 19, 2014 | Nikon Coolpix S210 Digital Camera
    Camera is not recognized by pc
    any card over 4gb will not be read by older computers. If you don't have a newer computer the SD card reader, avliable at walmrt under $10.00 will work.
    Jan 24, 2014 | Nikon COOLPIX L810
    How do I change coolpix s52 to change from internal memory to sd card?
    Try formatting the SD memory card using the camera's Menu setting.
    May 04, 2012 | Nikon COOLPIX S52 Digital Camera
    My Nikon doesn't read my memory card, it tells me no image
    Apr 27, 2012 | Nikon COOLPIX S230 Digital Camera
    Camera says out of memory won't let me take pictures. i cleared all the pictures out and still cant take pictures. What do you think the problem is?
    I'm assuming you are trying to use an SD card in your camera and not the internal memory. I suggest you format the memory card if you are sure there is nothing on the card. Formatting the memory card deletes everything on the card and sets it up with a file system that your camera recognizes. Follow these steps to format your memory card using your camera. 1. Turn camera off 2. Insert memory card 3. Turn camera on 4. When the memory card is inserted in the camera, the [Format card] option appears in the setup menu 5. Choose Format to format the entire card. Don't choose Quick Format 6. Wait until your card is formatted
    After formatting your memory card, try turning your camera off and on and you should now be able to take pictures to your memory card.
    P.S. If you remove your memory card you can choose Format Memory from the setup menu to format the camera's built-in internal memory
    Sep 01, 2011 | Nikon COOLPIX L5 Digital Camera
    How do I delete the pictures from my Nikon coolpix880 camera
    Use this option to format the internal memory or memory card. Formatting the Internal Memory To format the internal memory, remove the memory card from the camera. The [Format memory] option appears in the setup menu.
    Formatting the Memory Card
    When the memory card is inserted in the camera, the [Format card] option appears in the setup menu.
    or for more detail get the user manual from here
    http://www.nikonusa.com/pdf/manuals/coolpix/L12_en.pdf
    do rate the solution if helped
    Nov 28, 2010 | Nikon COOLPIX L12 Digital Camera
    How to transfer Nikon Coolpix camera pictures to memory card?
    Make sure you have an SD memory card inserted and your camera is on. Press the Play button to view your images. Now press menu and scroll down to the copy feature. You have two options, copy from camera to memory card is on top, and from memory card to camera is on the bottom.  Once you select your option, choose your pictures and copy.
    Regards,
    Lardzor.
    Aug 09, 2009 | Nikon Coolpix 4100 Digital Camera
    Camera does not recognize memory card
    It appears the SD card the retailer sold is not compatible with the camera. Put in a different memory card and camera works fine.
    Dec 28, 2008 | Nikon COOLPIX L18 Digital Camera
    Memory card cannot be used
    Follow these steps: 1. If you have a SD card reader, insert the SD card and look for it in Windows Explorer. In this case, mine was labeled F: 2. Right Click on the drive for the Card Reader (IMPORTANT) and choose FORMAT. 3. Format card with default settings. 4. Turn Camera on and go to MENU> FORMAT CARD 5. Before answering the next question, insert SD card into camera. You will hear it beep twice. 6. Choose FORMAT and the card should be formatted for use on the camera. Cheers!
    Sep 18, 2007 | Rollei Prego DP5300 Digital Camera
    Nikon COOLPIX S60 Digital Camera Logo
    57 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
