Question about MSI 661FM2-LSR (7060020R) Motherboard
Hi there is this small black chip thing on the board and its got a crack on it what is the problem is this going to b a problem ??/ my pc is still in working order plz any advise would b welcome
  • oogies783 May 15, 2009
    Thx just wanted a second opinion on if i should take it in or not.
    Sozrry im new at this so hope im doing this the right way
  • Peter Steiert
    Peter Steiert May 11, 2010
    Could you take a high-resolution picture of the device you're discussing? There's plenty of black chips on any motherboard.
  • 35 Answers
Hi
if its youre north or south bridge chip just make shure the crack
is not all the way trough the chip and if it is i would advise you to take in youre motherboard to the place you bought it and ask them for advise on what to do.
First time ever ive heard about this, however youre pc is still working so doesnt sound to serious plz keep me informed hope this helped
Kind Regards
Posted on May 15, 2009
C 4721 konica minolta bizhub 250
Sir/Mam, there is a small Intergraded Circuit Chip That is removal on the Copier control Board that has failed. The Card is located on the back of the copier this chip my also not be plugged in properly. I've never send that code before.. That chip carries the serial number and counter info (Digitally) When ever that board is swapped out you have put that chip on the new board. If not the chip then might be the board itself.
Dec 18, 2013 | Minolta bizhub 350 Black and White Copier
My 42" rca flatscreen has a picture but no sound the sound started cracking then went away no i have no audio what can i do to fix this
Check to make sure that your speaker wires are not pinched. If the wires look good, then your main board is the culptrit.
May 17, 2012 | RCA Televison & Video
3 long beeps when memory installed on gateway 700s lx3
The Code Beep Manual tells us that 3 long Beeps shows you that there is a problem with the RAM. Its either it is not installed properly, or it is faulty etc. But in your case, This has to do with the installation of those chips. I would suggest that you install only one chip at a time and check if the system will recognize it and be able to boot. If it does, put it aside, try the next one until you find out which one is causing the problem. If all the RAM chips work, then try two chips at a time, and make sure you keep on trying them only on selected slots, so that it helps you to narrow down your problem because the problem might not reside in the RAM chips but in the slots. Make sure the slots are clean, no dust particles in them, since dust particles can cause static electricity to build up around the system board causing the system to halt.
The other thing you need to consider is how you handle the RAM chips themselves. Make sure you do not touch the part that connects to the slots, because this can also create static electricity that is harmful to your computer. Again check the small lines that go into the slots on thr RAM whether they are all intact (have a goldish shiny look). At times, these lines can burn out causing a discontinuity of the current on the board.
Mar 01, 2012 | Gateway Computers & Internet
Toshiba tab turns on but Screen stays black what do I do
I would check the ram chips first,, pull them out and reinstall them, most of the time this will work. if not.... try starting the laptop with only one ram chip installed, then try the same thing with the 2nd ram chip install,, test one at a time..
If this dont work it may be a bad GPU connectoin to the mother board,
This can be fixed but in most cases a new mother board is needed.
Jan 11, 2012 | Toshiba Computers & Internet
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
How to repair cracked corner of black ceramic cooktop
Epoxy would not work. If it is a very small chip and is NOT STRUCTURAL or in the heated are you could TRY the adhesive used for rear view mirror to glass attachment.
Sep 13, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
My laptop has its screen divided into 8 parts, 6 though but with 2 more smaller parts below. and a fat black vertical line. please help me it Hp pavilion Dv6550ee
sounds like the screen has had damage thru impact
Only solution is to replace the LCD panel
Please rate me thanks
MISTERDJ
Aug 12, 2009 | HP Computers & Internet
Put in new black cartridge and told it is incorrect
If it still recognizes the old cartridge and the new one is the same modle then the printer is likely fine. Chances are the new cartridge either has something obstructing the chip or the ID chip may be faulty.
Best bet is to locate the small chip and circuit board for the head and dab them clean with rubbing alcohol, try it again. If that doesn't work either return to the store you bought the cartridge at or call Dell support and report the problem. They will most likely issue you a replacement cartridge.
Hope this helps,
Chris
Jul 09, 2009 | Dell 962 Photo All-In-One InkJet Printer
Curtis mathes tv - model cm25020s
had the same problem if you have any skills with soldering open it up and check on the pins on the thing in the back lefthand corner. On mine the solder has a circular crack around one of the pins that when the back was on on it pushed the chip itself up and cause that one pin to not touch. The thing i refer to is the black tower that has 2 philip type "screw" that you turn to change the defalt color or somthing like it. well hope what i said help if you have not trashed it or got a new tv... or both.
Oct 13, 2008 | Televison & Video
Picture bows on top and bottom of picture......
Your problem is the convergence IC'S. They have STK ###-### the # are numbers. You can get parts at http://partstore.com. If your not a tech and an experimenter or a handi person Pease be aware of the hi voltage inside these sets. Also be aware your going to need to unsolder and resolder the ICs in and from the printed circuit board. Good Luck
Aug 11, 2006 | RCA P46924 46" Rear Projection Television
MSI 661FM2-LSR (7060020R) Motherboard Logo
159 people viewed this question
Top MSI Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Terry Hair
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
