Question about Dryers
Not enough heat
Electric Frigidiare dryer GLER331AS1 is not heating up after repugging it in after power went out due to storm. Manula sys possible cause as one of the fuses. If this is true--where are they located and how do you check and replace. Thanks
    Genius:
  • 3,422 Answers
If your dryer doesn't heat, check these:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on May 15, 2009
Tip
Electric dryer will not heat?
If the electric dryer does not heat at all then there are some possibilities that have to be checked to confirm the fault.
1)check whether you are getting power to the dryer from electric out let to which the dryer is connected. The power problem can also occur if the fuse is blown or the circuit breaker is got tripped.
2) Other possibility for dryer not heating is the blown thermal fuse. The thermal fuse is located to the exhaust duct inside the back cover panel. This fuse blows out if the dryer gets overheated or any short circuit occurs in the house when dryer is in working.
3) The other possibility if the power is ok and if the thermal fuse is ok. Then the problem can be due to fault in the heating element. The heating element looks like a long coil of special wire. You can check heating elements continuity with an ohm meter. If there is no continuity that means the element is bad and you need to replace it. The heating elements cannot be repaired it should be replaced if faulty.
4) But if all the above mentioned possibilities checks out OK, and still the same problem, then there is a fault in the wiring. Check the main power cord of the dryer which you connect in the electric out let. If the power wire is got internally burned out or got cut in between the dryer will not get proper power and will not work Due to partial power.
This will help. Thanks.
on Mar 23, 2010 | Dryers
First it started squeaking when it was running. Now it squeaks and doesnt heat while running Model #GLER331AS1
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 13, 2011 | Frigidaire GLER341A Electric Dryer
No heat in the dryer
hello km....if this is an electric dryer, there are two possible reasons for no heat. The common reason is that the heating element is bad and must be replaced. The uncommon reason is that one leg of the 220 electric entering the dryer is bad, due to a faulty breaker or a loose connection resulting in the 110 volt components working but not the heat. Joe
Apr 03, 2011 | Kenmore Dryers
NO HEAT BUT TUMBLER WORKS on GLER331AS1 DRYER. Want to check fuses. How do I access them?
There are no fuses,I would check the dryer vent and make sure it is not stopped up with lint, then I would check the elements.
Mar 02, 2011 | Frigidaire GLER331A Electric Dryer
I HAVE A FRIGIDIARE DRYER MODEL NUMBER LEQ1442ES0 AND IT DOES NOT HEAT. I HAVE TESTED EVERYTHING WITH A OHM METER AND IT CHECKS OUT GOOD. WHAT COULD BE CAUSING THE DRYER NOT TO HEAT UP?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 10, 2010 | Dryers
My Frigidiare dryer will not heat up. Is it fried or what?
heatman101
Jun 04, 2010 | Frigidaire FGR341AC Electric Dryer
Heating element drawing lots of power, big bill power
Well a dryer heating element does draw quite a bit of amps(that is why it is 220) but it cycles on and off & it is not an appliance that is used everyday. The first think I would do is read the electric meter and verify that it was not misread before condeming the dryer. If the electric meter reads are correct then it is possible it could be the dryer heating element shorting. How much do you actually use the dryer? Is the heating in your house electric and have you been using it? You could also have your electric company test the meter. Look at your usage of electricity for last year at the same time(it will be on the bill) and see what the number was.
Oct 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
Dryer only blowing cold air
First reset circuit breaker since it's 220 set set up is possible to have tripped one of the breakers not likely but possible. Next if that does not do it you need to buy an ohm meter and open the port to get to the heating coil so you can test the heater wire putting it on ohms and with it unplugged put the ohm meter leads on the two terminals and see if you get a reading, if the needle moves it's something else if it don't it's the heating coil, plus there is other things to but that wheeI'd start. but if your squeamish with 220 then call a appliance man, anyone worth his SALT Will have it fixed by the time you went to the store and bought the meter took it apart and replaced it.
Jun 26, 2009 | LG DLE5977 Stainless Steel Electric Dryer
Dryer not heating...tumbles and blows OK - is 2 30 amp fuses enough
ELEMENT IS BAD NEED TO HAVE A SERVICE TECH REPLACE THE HEATING ELEMENT
May 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
Top Dryers Experts
