Question about Dell 2.8 GHz Second Processor for PowerEdge 830 Server Pentium 4 (DF904) Processor Upgrade
My Dell C640 laptop freezes normally just some few minutes after booting
  • pin_0018
    pin_0018 May 11, 2010
    Nop it not Virus. C640 has a Genric Issue with Heating.Check the Primary Fan position bottom upper right handside is it Spinning also the Secondary Fan which is behind the Laptop wer u connect the PowerCord.
  • Peter Steiert
    Peter Steiert May 11, 2010
    How old is it? Does the cooling fan(s) spin rather loudly or very quickly? It sounds as if this issue is heat-related. Otherwise this is an issue with a Virus.
  • Dell Master
  • 2,404 Answers
When the laptop freezes up on you does the keyboard or anywhere on the top cover feel very hot if so check to see if the fan is even blowing, if it is blowing then its possible there is dirt on the heatsink fan that is blocking the air flow and thats causing the overheating. You would need to take apart the laptop to get to the cpu heatsink to remove all the dirt.
if the fan isn't running at all then you would need to get a new fan.
If the fan is running and there is no dirt or debris near the heatsink then that means the motherboard is not reglulating the voltage properly and the motherboard needs to get replaced.
if nothing is feeling very warm or hot to the touch and the system is locking up then the hard drive may have bad sectors and the hard drive would need to be replaced.
Posted on Jun 21, 2009
Dell latitude c640. turned on this morning and got the caps light to blink a few times and cd drive to power up then nothing. Just turned itslef off. Has been working fine until this.
several reasons why this will occur:
1) battery is not fully charged - you might try rebooting with the computer plugged into a wall socket.
2) computer's main power supply has been damaged and needs to be replaced.
3) virus - though with most standard virus' , you can still boot up, there are a nasty few that will wipe your entire computer including the operating system.
Mar 31, 2010 | Dell Latitude C640 Notebook
Dell latitude laptop-freezes after running for a few minutes/sometime on start-up/screen on but no response /fan stops running and nothing responds
Im assuming its a C64, these notebooks have overheating issues.
1. make sure the fan has room to breathe, and is clean of dust.
2 Dell Inspiron/Latitude/Precisiion fan control utility will help cool your processor ... http://www.diefer.de/i8kfan/index.html
Jun 04, 2009 | Dell Latitude C640 Notebook
Dell C640 Turn On Problem
Probably an overheating problem. The best thing would be to disassemble your notebook, and clean the heat sink. If you're not experienced with this kind of things, don't do it. You can try to use a vacuum, or take it to a specialist.
Apr 11, 2009 | Dell Latitude C640 Notebook
Laptop
clear the cmos, or remove the battery for a few minutes, that will clear any bios password
regards
Dec 13, 2008 | Dell Latitude C640 Notebook
Dell latitude c640 laptop
This could be caused by a number of thing, bad battery, bad power supply, bad memory chip, bad processor, and a bad component on the motherboard. Start by checking the output of the power supply with an ohm meter. The output rating will be on the power supply or you can go by the input in the machine. Then try starting without the battery. Then remove the memory and try with one chip then the other. At this point, if the problem persists, you will need to take it for a professional diagnosis. They will be able to test the processor and motherboard to find the exact problem component, and tell you whether it's replaceable.
Jul 23, 2008 | Dell Latitude C640 Notebook
Booting problem
Try putting the computer into safe mode by holding down on the F8 button and selecting safe mode during the boot process. Once you get to the safe mode screen and windows appears, restart the computer.
If that doesn't fix the problem you will have to restore Windows.
Jun 12, 2008 | Dell Latitude C640 Notebook
I need to get a graphic card for my dell latitude c640
log on to www.support.dell.com
there is a search box at top right corner
go for an Nvidia card 512 MB
but this would be the best
Jun 10, 2008 | Dell Latitude C640 Notebook
Dell c640 laptop
it sounds like your hard drive has some problems with it. Try replacing your hard drive and reinstall your OS.
May 17, 2008 | Dell Latitude C640 Notebook
Dell laptop memory install
available physical memmory is what all your programs on your comp is using like windows virus software drivers im thinking you probably have spyware or bugs in your comp that could be bringing memmory down
total physical memmory is what you just put in
May 09, 2008 | Dell Latitude C640 P4 Mobile Notebook
Dell 2.8 GHz Second Processor for PowerEdge 830 Server Pentium 4 (DF904) Processor Upgrade Logo
414 people viewed this question
Alun Cox
