Question about GE Spacemaker JVM1640SJ Microwave Oven
Make it stop!
After tripping the household breaker by accidentally touching the bottom light socket (live) with a screwdriver - I know, I know - stupid move on my part - the microwave now runs constantly. Punching any or all of the buttons has no effect. The only way to shut it down is to flip the household breaker switch. What is happening here? How can I fix it?
  • GE Master
  • 9,100 Answers
The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Oct 22, 2007
I need to know what is the first thing to look at when a mircowave trips a circuit breaker
First off you probably have too many appliances running off the same circuit as your microwave. Try using a different socket. This has happened to me many times at various houses I've lived. For example... My wife uses the hairdryer when I'm warming up some coffee...trips breaker. It basically breaks down to how many circuits your breaker box holds and how powerful it is. Imo Hope this
May 31, 2015 | GE Microwave Ovens
I can't get my electricity to come on
Check the fuse panel first. All the breakers may be turned off to prevent accidental blowing of fuses when hooking up power. There may also be a main breaker separate from the fuse panel. Read your manual if you have one.
Oct 11, 2014 | Microwave Ovens
Trip Circuit Breaker
The circuit breakers may both be functioning properly. What might be happening is that both circuits have other current drawing appliances on them. The circuit breakers react to the sum of all of the currents drawn by all of the devices on that circuit. So, if you have a 15 amp microwave and an 8 amp refrigerator on the same circuit, you would overload a 20 amp circuit by 3 amps.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Apr 14, 2014 | LG LMV1813ST Microwave Oven
Lg microwave mv2297fspl
Magnetron is gone, just to be sure remove the microwave and use on a different socket. sometimes the breaker becomes faulty after 10 AMPS.
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Nov 21, 2013 | Microwave Ovens
The trip breaker in my home for the electrical outlet keep tripping off what do i do. the breaker in my electircal box for my electrical socket keep tripping off
go to the qualified electricians on your place... but there is some helpful tips that can help you.. (1) for continued protection before starting. turn off the main circuit breaker. (2) unplug all the appliances or equipment installed... (3) check all the wall socket outlet... look for any damages on the wall socket... if the wall socket outlet have no signs of burned or wet marked, try to turn on the circuit breaker. check if the problem is solved.. (4) if the wall socket outlet have a signs of burned or wet marked.. just replace that w/ the same type of socket... check also the appliances that may caused the problem... the easiest way to know is to look at the socket plug itself... ty
Jun 21, 2011 | Microwave Ovens
This oven is fitted to my new (to me) rv. the convection bit is fine, but the microwave trips the 15A breaker. have changed the breaker, still trips.
Yes the breaker is to stop firs etc, you should NEVER EVER simply re-set a breaker without finding out WHY it tripped. I suspect your oven has developed a Short Circuit fault. Please DO NOT touch it while plugged in you risk electric shock. Please remove from power and get it looked at by a qualified person. Please ask for "Quote" before proceeding with any work. a lot of the time replacement is cheaper than repair.
Mar 19, 2010 | Sharp R-1874 Convection/Microwave Oven
Model mw8109w just stoped .No display of clock or anything.
You have checked the circuit breaker - RIGHT?!?!? Looked for a tripped GFI?!?!?
Unplug the machine ... Remove the cover. DONT TOUCH THE SILVER CAN - LETHAN
Look for a fuse on the floor of your machine near where the cord enters. If you have a volt/ohm meter, check it with that meter. If you dont know what Im tralking about, get a paper clip, a flash light light and a flash light battery.
Bend the clip in a manner that will allow you to touch the both the bottom of the battery and the side of the flash light light while put place the metal tip of the light on the top of the battery. The light should lilght.
Now, place the fuse between the bottom of your battery and the end of your paper clip. If the light lights, your fuse is good. If it doesn't llight, your fuse if probably bad.
Get a replacement at an appliance or auto parts place.
I hope this solves your trouble.
a
Sep 27, 2009 | Emerson Microwave Ovens
The under unit light burned out and tripped the circuit breaker. Replaced bulb and reset breaker but light doesn't work. I see there is an internal fuse. Could this be the problem as there is no power...
These remarks are not make and model specific.
Did you test the new light bulb?
I would not normally expect a burned out light to trip a breaker.
You may have a blown fuse. I suspect the fuse you see is to protect the oven. If you popped a breaker, you may have blown a fuse. I'd be looking for a short somewhere, maybe in the wire that powers the light, maybe in the hardwire that supplies the oven.
Make sure you turn the power off before you go poking around. And, above all, avoid the silver can inside, it IS lethal.
Let me know if this helps.
A
Sep 21, 2009 | Maytag MMV1153A Microwave Oven
I have a Panasonic microwave model nn-sa616wx sn 58100747 it keeps triping the breaker after it operates for awhile we have taken a amp reading and it draws 17.2 amp.This is a new microwave.
Safety first, unplug your microwave from socket outlet.Needs to troubleshoots series of components using eliminating method to know which component(s) that causes breaker to trip off. It is obvious that a componet(s) "shorted out".Remove your fuse and replace it with resetable breaker tested.
Remove leads of the transformer output(secondary side). plug power cord run the microwave.If does not trip off the cct breaker change your transformer. do the same to capacitor lead, one after the other until you discover which component that shorted and cause your cct breaker to trip off.
Jul 24, 2008 | Panasonic Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
43 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
