Question about Garden
Starts but won't speed up enough to run
I have a kawasaki hedge cutter. Single sided blade. (approx 30") Engine number 466734 code TG018D-BF92. It starts and begins to run but will not pick up when throttle engages. Just doesn't speed up. Blade is free enough. Is there any manuals which can be downloaded anywhere? I've tried running with the air intake cover off and is appears to spit fuel out whilst running. Any advise would be greatly received, thanks Dan.
  • Anonymous May 19, 2009
    Thanks managed to get very significant improvement. I think that what ever caused the blockage may have be due to poor combustion so will now clean carb and reset, runs for longer but still stops short of cutting speed.
    Sniper:
  • 57 Answers
If this is a 2 cycle engine the problem could be that the exhaust is clogged. Most 2 cycle engines have a spark arrestor on the muffler which clogs. could also be the exhaust port from the engine. remove the muffler and check it out.
Posted on May 15, 2009
Why does my kawasaki hedge cutter start easily but stop when tilted at a certain angle
ummm, because the fuel pick up is not in the fuel. I bet it is ok when the tank is completely full right?
Sep 19, 2014 | Garden
Why does my kawaski khs750b hedge cutter start easily but stop when tilted in a certain position
Answered your own question : generally the fuel supply to the motor is through a small hole at the base of the tank , at full you could probably tilt more aggressively and the line is getting fuel , however as the fuel runs down the fuel is on one side of the tank and is essentially not getting fed to the motor , you'll notice tilting it from horizontal to left you will get cut off , tilt to right it'll keep running depends on the locations of fuel line however , cars pre fuel pump days had similar problems
Sep 19, 2014 | Kawasaki Outdoor New kawasaki Hedge...
I have a husqvarna122 HD 45 hedge trimmer and it will not stay running it is wide open all the time the only way to keep it running is to run the machine at 3/4 Choke. when running the machine sounds like...
While not being familiar with your machine, there could be several causes, the first that comes to my mind, based on your analysis ["...sounds like it is under load."], is that there IS SOMETHING CAUSING the system to "BE UNDER LOAD"!!!!!
Now, considering what could cause such a load on the system THREE things come to mind:
  1. An ACCUMULATION of trimming DEBRIS has gotten between the cutting blade and its support frame, causing the blade to severely bind / "drag"!, or
  2. The bolts or screws holding the cutter blade and its NON-moving support frame together have been OVERTIGHTENED, or
  3. A bearing, or bearings, in the engine are failing and are beginning to seize.
  4. On some machines, the connection between the engine and the blade involves an eccentric arm, with a BEARING. IF that bearing is beginning to fail, and thus seize, that could be the cause od the "unknown" extra load.
Aug 23, 2014 | Garden
Engine running, blades not moving
There is a big steel cable/wire type thing e in side the tube of the machine connect motor too head and itz broken look at small engine shop online
May 31, 2014 | Husqvarna 122HD60 Hedge Trimmer
Stihl HS 81 RC
You may be trying to cut material that is too large
Oct 05, 2013 | Garden
In need of manual kawasaki hedge cutter
try the piratebay
its a utorrent thing. type in like kawasaki hedge cutter kht600d manual
Mar 13, 2012 | kawasaki Kht600d Gas Hedge Clipper Trimmer
The cutter action is jammed
Ensure blades are sharpened. If there are burs on blades they can seize.
Blades should be lubricated with WD40 , waste oil or other lubricant.
The bolts holding the two blades together shouldn't be too tight.
May 13, 2011 | kawasaki Garden
Model HTC24 Flymo Hedgetrimmer
Are both the blades still moving? Are the blades sharp?
Aug 01, 2010 | Husqvarna Garden
The nuts on the bolts holding the blades together keep coming loose. How do I tighten them properly?
you can put a drop of loctite on each nut but they shoulded keep undoing if u are doing them up tight enough to tight and ytou will snap bolt you could replace with locking nuts
Jul 02, 2010 | Tanaka 30" Single Sided 24cc Hedge Trimmer
Garden Logo
417 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
