Question about Dell Inspiron 530 Desktop Computer (ddcwda1_7) IntelPentium dual-core processor E2140 (1MB L2,1.60GH
Top disk drive wont open
My disk drive wont open
    Genius:
  • 3,422 Answers
If you disk drive won't open then:
1)reset the PC bu unplugging all the cords from the back for 1 hour.After 1 hour plugin all the cords and then press and hold the disk rive button.It will come out.
2)If the **** drive still won't open then take a paper clip and insert it into the hole.You will find this small hole beside the button of your disk drive.You will have to insert the paper clip in it and press and hold for 1 min.It will come out.
Posted on May 15, 2009
Disk drive door wont open. LED light comes on an hums, but tray wont eject to open. Where is manual eject hole located?
Below the drive tray there is a tiny hole, straighten a paper clip and gently insert the paper clip into this hole. Push the paper clip and the tray will release and pop out, then pull the tray out to the fully open position.
Mar 02, 2012 | Computers & Internet
Can't get my lap top to open the bl--dy thing Lap top see's it but won't open it up can any one help before i put a hammer to it i've had it for about 2yrs now but haven't been able to access it now for at...
Try to connect the external disk-drive to a different computer.
If you still cannot access any files, then either:
* the USB-to-disk-drive adapter inside the case is malfunctioning,
* the disk-drive inside the case is malfunctioning.
Read the serial-number of the external disk-drive from the case, and access the manufacturer's web-site, and check to see if the "warranty" for the device is still available. If so, the manufacturer will replace the device -- you might have to pay "shipping" to send your device to them.
If the warranty has expired, open the case, remove the disk-drive, and connect it as a "slave" disk-drive in some desktop computer, to see if the USB-to-disk-drive device was the problem.
While the case is open, you could purchase a new disk-drive to fit into the case, and then close the case, and once again have a working "external" disk-drive.
Aug 16, 2010 | LaCie (300770) 250 GB Hard Drive
A dvd is stuck the door wont open
Remove the top cover.
There will be several screws holding the top on. Remove all and slip the top cover backward to remove.
This will expose the internal system. You will see the disk inside under the laser disk reader.]
You will see a gear the drives the sliding disk holder/loader. This is the part you see come out of the door onto which you place the ****. Roll the gear with your finger and the holder will move. Keep going and the disk will come out as normal. Remove the disk and try to plug the unit in and press the close button. The unit may close as per usual. If not rotate the gear again until the holder goes full back inside. Again try to plug in and press open. It may start working. If not is had problems.
Hope this helps
Mar 08, 2010 | Symphonic WF803 DVD Player/VCR
I took apart my xbox 360 and when i turned it back on i saw that the disc wasnt turning fast enough and it just saids open tray
the disk is not being spun more than likely. thats why i always get open tray. wat u need to do is this
1) unplug it all and take it apart
2) get to the disk drive
3)unscrew the 4 screws on the SIDES onf the drive. not the 2 in the middle 4)take off the cover GENTLY
5)put the drive back intoplace without the top on it
6)plug it up and turn it on
7) observe the disk want to spin but it wont. there is not enough pressure to get it going, wat u need to do it give it a little "push-start" spin it while applying pressure. it may take a few trys to get the disk going fast. it will need to start going very fast.
8) when it does that, quickly place the top back onto the drive without screwing it back on.
it should contunie to spin. turn it off, unplug it, screw the top back onto the drive, then reassemble the 360. works for me EVERy time
Jan 03, 2010 | Microsoft Xbox 360 Console
My wii wont except disks, it will eject it, but not take it!
When you remove the drive there is a small circuit board on top of the drive near the loading tray that is connected with a small ribbon cable. This is the photocell sensor board that detects your disks and engages the motor to take the disks in. It could be out of alignment with the photocell emitters or loose connection with the ribbon cable. However I think this will only effect the intake of the disk into the tray and not have any effect on ejecting the disks. Have you checked the 'n-fuse'?
Dec 28, 2009 | Nintendo Wii Console
Door well not open
hit the top of the consel were the disk drive is it could just be dusty and has 2much friction to move on its own. if that still dosent work then push the buttom to open it and get a thin object (like a butter knife or sum that wont damage the consel) and use leverage to open it but make sure the consel is trying to open it itself or else you will jam the gears if you dont do it rite
Dec 15, 2009 | Microsoft Xbox 360 Console
Wont load disks to watch movies or play games.All menus works but wont play games.
Most likly a dirty lense or fault blu ray disk, i run a cheap service to fix the dirty lense a blu ray repair would cost about 110 cause u would need a new drive but if you are out of warrenty open up the top get into the disk drive and apply waterd down alcohol to a qtip and clean the lense , it should fix your problem, here is my link if you dont want to get into it by yourself http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=120504910103
Dec 11, 2009 | Sony Playstation 3 (PS3) Console
My xbox's disk drive wont open can you fix it?
Take off the top cover to the xbox, take out the disk drive and open it up and replace the snapped rubberband that acts like a conveyer that opens up the disk. thats was the problem in the first place the conveyer broke off
Aug 23, 2009 | Microsoft Xbox Console
Some disks on a drive will open some wont
Hi there.
If this is a floppy drive then the heads will be dirty and need cleaning just like the old tape player did.
I'm not too sure nowadays but you used to be able to get head cleaning kits for floppy drives.
Also i would suggest that when the drive reads the disks transfer your rare pics to the computer and also back them up to a flash drive or CD.
Good luck and thanks for using FixYa!!
May 25, 2009 | IBM Computers & Internet
My A drive is external and wont open any disk...it wants to reformatt my disk but i have rare pics on it and dont want to lose them
When the floppy drive is external and won't read a disk this means the head is misaligned/dirty/damaged. There is little you can do but try a head cleaning disk, but in my experience its normaly quite fatal when they come up with that.
Dell Inspiron 530 Desktop Computer (ddcwda1_7) IntelPentium dual-core processor E2140 (1MB L2,1.60GH Logo
82 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
