Question about Dometic RM2852 Refrigerator
Not cooling bottom refer unit stopped cooling & freezer is only cooling but freezing. what do I do?
  • blastducks May 25, 2009
    neither freezer or refrigerator are not cooling
  • 159 Answers
Low gas in the system
Posted on May 15, 2009
Maytag MBF1958WEW1 refrigerator not cooling but bottom freezer is fine help
Sounds this fridge/freezer has a refrigerant leak. Eventually the freezer will also stop freezing. Need to find and fix leak and refill with refrigerant.
Feb 01, 2018 | Maytag Refrigerators
Lg lfx25960st not cool enough
1. What are your controls (freezer & refer) set at?
LG recommends 0 deg for the freezer & 37 deg for the refer.
2. The way a modern refrigerator works is, the freezer is cooled directly and cold air then is blown into the refer section. The incoming vents in a French door LG are at the back, top. Return are at the bottom. Make certain that nothing is blocking these vents and than the refer has good air circulation.
3. Vacuum the coils at the back of the refer. A large build up of dust, dirt, animal hair etc. will affect efficiency.
Apr 14, 2014 | LG LFX25960 Bottom Freezer French Door...
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
The fridgefreezer has power but no cooling or freezing
Most likely there is low voltage to the unit or the compressor is bad. Is the condenser coil very dirty and if this unit has a condenser fan does it run?
Nov 10, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Side by side refrig. side not working;freezer freezing up
The unit is not defrosting. Either the defrost clock is defective or the defrost heater is not working. Defrost clock is normally located behind the bottom kick panel. Use a large standard screwdriver and turn the center screw clockwise very slowly until the compressor stops. Wait 20 to30 minutes the compressor should restart, if not the defrost clock is defective. Checking rhe heater you'll need a vom meter or amp meter.
Sep 12, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Refrigerator stops cooling
Your defrost system is bad. When the unit freezes up, the air flow shuts down and you don't cool. When you turm it off, it thaws out and starts to work again. We have parts so give us a call if you like. Hope this helps! Ella
Aug 18, 2009 | Kenmore 63222 / 63224 Bottom Freezer...
Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
May 30, 2009 | Refrigerators
Amana Refer. runs all the time.
Have you ever cleaned the condenser coil in the back or under the bottom of the refrigerator. Dirty coil will cause this problem, also make sure the little fan motor in the back is working if it stops you can get the same condition. If not these two conditions you may be starting to have a refrigerant problem.
The unit gets low on refrigerant and just dosen't cool properly.
May 17, 2008 | Amana Refrigerators
Dometic RM2852 Refrigerator Logo
197 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
