Question about Ford 8n,9n,2n, Tractor Starter With Drive
Is their a common problem with ford 8n starter drives
  • dyna58d May 16, 2009
    Hi john, the thing is i replaced the starter drive a few months ago, and it worked fine, but now it sounds like its kicking in and out while i try to start it. it sounds like it coming a part. i removed the starter and nothing looks bad. i ckecked the starter ring gear and it good. any more help would be great!!!! thanks dave
  • dyna58d May 25, 2009
    hi john, found the problem, the starter drive has a crack in the gear. have to get a new one. thanks for ur help. dave
  • 246 Answers
Hello:
>>Not to my Knowledge.
>>Most of the Problems are the Common Ones; Brushes, Bushings and Solenoids are the Most Common Problems with the Ford "N" Series Starter Systems.
>>Once in a Great While you will have a Bad Field Windings or a Bad/Damaged Armature (Due to Bad Bushings), but Not that Often.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 15, 2009
  • John C Bridgers Sr May 16, 2009
    Hello dyna58d:
    The Problem you Described is Usually Caused by Low Voltage going to the Starter or a Bad Solenoid.
    Good Luck
    Respectfully
    jbridger (John)
Taking starter off
Go to www.ssbtractor.com Then 8n starter removal
Mar 27, 2014 | Ford 8n,9n,2n, Tractor Starter With Drive
Ford 8n Is It Time to Replace the Starter?
Bad brushes it is not making contact with the brushes.
Jun 22, 2013 | Ford 8n,9n,2n, Tractor Starter With Drive
My ford 8n starter only clicks, solinoid ok
Are you getting same voltage on each side solinoid when key turned.
Feb 28, 2013 | Ford 8n,9n,2n, Tractor Starter With Drive
How to remove starter drive on ford 9N
You need to compress the front of the drive enough to drive out the roll pin,then the drive should slide right off.
May 06, 2010 | Ford 8n,9n,2n, Tractor Starter With Drive
My ford 8n starter just clicks now. Is there anyway to get this to stop and work corectly?
You likely need to replace the starter solenoid switch,if it just clicks then one of the contacts has worn out.If the starter is a delco,order one for a Chev half ton 1980, and it will be about $30 cheaper and do the same job.
Feb 15, 2010 | Ford 8n,9n,2n, Tractor Starter With Drive
My 1949 8N Ford tractor, the starter just spins
My thought is you need a new "bendix" for lack of a better word. The device I speak of spins out and connects with the flywheel. There is the possibility you have electric problems but based on what you say, I think it is mechanical.
Thanks for posting your question at FixYa.com
Pleae vote
thank you
a
Nov 09, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Replacing 8N starter motor
IT helps to loosen the oil canister ahead of the starter and then begin inserting the starter with it tipped upwards and then gradally lift it as you insert it.
The hole should be oblonged out to make for easier insertion of the starter shart..
good luck.
Marc
Aug 09, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Ford 8N has a broken tooth/teeth on ring gear. How
Hi..my name is Keith..and i restore 9N's,2N's and 8N's....and to replace the ring gear..you split it there at the back of the engine..and its kind of a big job..so i would check the starter 1st..to make sure its not a starter problem..i hope this helps..if not please write back..i love tractor problems
Jul 09, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Starter on ford 8n tractor will not engage.
Did you check for voltage at the starter connection at the starter connection AFTER the solenoid.......when the solenoid is energized?
Just because it clicks does not mean it is sending power through.
Does the starter have a good clean ground?
Use a battery booster cable and supply your own battery power right to the starter to check it.Try grounding it too with the other battery booster cable.The starter drive is only used when the starter is turning as it is thrown out into the teeth of the flywheel...cranking the engine and back out away from the flywheel when the starter stops turning.
Apr 05, 2009 | Ford 8N Tractor
Ford 8n,9n,2n,  Tractor Starter With Drive Logo
600 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
