Question about RCA L32W11 32 in. HD-Ready LCD Television
Top inch and a half of tv picture cut off.
The pic on m;y tv seems to have moved up.  it cuts the heads off people.  the screen has a full picture.  i can't find the owners manual.  there are no knobs to turn to raise or lower the picture
  • 709 Answers
Hi JDRJR35,
Here is the internet address on the usewrs manual for your LCD TV.
http://tv.rca.com/RCATV/RL/1652880A.pdf
Now I will read through it and write down the procedure t be sure you get what your need.  See my next post in a few minutes.
Posted on Oct 16, 2007
  • Greg Stokes
    Greg Stokes Oct 16, 2007
    Geometry Menu
    These adjustments apply to the CMPT and VGA inputs:
    Auto Adjust Adjusts the position of the picture automatically.
    V. Position (Vertical Position) Adjusts the picture’s position upward
    or downward.
    H. Position (Horizontal Position) Adjusts the picture’s position left or
    right.
    Phase Adjusts the picture if there is fl icker of screen letters, color
    misalignment, or blurring.
    Clock Adjusts the clock sync of the picture.
  • Greg Stokes
    HI JdrJr35,
    I truly hope this is what your looking for. I give it my best effort and would appreciate a solved vote. Thank you....
Picture no longer centered in VGA mode
Is there any magentic material in and around that area?
Jul 18, 2012 | Televison & Video
Cuts peoples heads off, doesnt autoformat
uncheck format , format manually. use "full" or "panorama" setting
Jan 02, 2010 | RCA HD52W59 HDTV Projection Television
The top of my picture is cut off.
Change the video output to wide screen
Oct 15, 2009 | Sony Televison & Video
Picture too big
It seems as if your tv is in "crop", "Zoom", or "full" mode. Select letterbox, normal, or full-screen mode. Look in the manual for exact instructions.
Jul 15, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Top and bottom of the picture is cut off.
look for a button on the remote control that says, "pic size"," zoom","aspect" and scroll through until you get to 16x9, full , fill screen . i can't remember what this model states on the screen.
Feb 19, 2009 | LG 42PC3D 42 in. Plasma Television
Screen size
YOU MUST GO INTO YOUR PS3 VIDEO SETTINGS MENU AND SET YOUR HDMI TO 1080P AND YOUR PICTURE SHOULD BE OK
Nov 02, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Picture jumps
you might have bad caps or the vertical output integrated circuit, try to locate the vertical ic and check the surrounding areas for bad capacitors.
good luck
caypianan@yahoo.com
Oct 23, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Picture is cut off at top and bottom
I had the same problem with my westinghouse 47 inch HDTV. It turned out that someone had inadvertently hit the "format" key on my satellite (Direct TV) TV remote controller. If you have satellite TV you might want to check this out. I set it back to the previous setting and I get the entire screen. Hope this helps someone.
Oct 20, 2008 | Vizio L32 32 in. LCD HDTV
RCA TruFlat Tv problem
YOUR TV HAS A RETRACE PROBLEM,FIND THE CAPACITOR 35V/100uf,1V/10uf AND COLDSOLDER FIRST THE MAINBOARD BEFORE YOU REPLACE THE COMPONENTS.
Jun 09, 2008 | RCA TruFlat 27F520T 27" TV
Cutting off the picture
please try once more in the memu on tv
Oct 14, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
RCA L32W11 32 in. HD-Ready LCD Television Logo
143 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
