Crosley CW5000 Front Load Washer
Problem for Crosley CW5000 Front Load Washer
Agitates and drains but will not spin
By traczkowski on May 15, 2009
Top load Crosley #CW5000W agitates and drains but does not spin.
Clarification Request
Posted by jumptrout51 on May 15, 2009
If the lid switch is good you will need to replace the thrust bearing kit.
You can open the control panel and jumper out the lid switch. If it does not spin while jumped out the thrust kit on the lower transmission under the machine needs replacing.
Best Solution
posted on May 15, 2009
Very Helpful)
localwonder
Rank: Guru  Washers & Dryers  Expert
Rating: 92%, 2840 votes
Hi, there is a lid pressure switch that controls the motor during the spin cycle. if the lid is up, it will close open the circuit that controls the motor and it will shut the spin down.
Now, if this lid switch is broken or lose, it will not allow the spinning action at all. your lid pressure switch is damaged or lose at this time. i recommend inspecting this switch that is located under the lid rim. check the wires and connection clips for a lose fit. if the wires and clips are in good condition, this Will confirm the switch failure. replace in this case. i will link you to a replacement switch you can order on line if you choose.
CLICK HERE.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Crosley CW5000 Front Load
Questions and Unsolved Problems for Crosley CW5000 Front Load
Do you recommend Crosley CW5000 Front Load Washer?
Answer
Answer
washer wont spin o drain right pause lights up before and during spin cycle
Answer
Whirlpool Estate etw4300sq washer squeaks during spin cycle
Answer
I have a Crosley top loading washer that will not turn off, and it continues to pour water into the... (More)
Answer
when i put another load in when it was time for the cloths to spin it spins off balance with a loud... (More)
Answer
water drains out but tub will not spin I have lost owners manual and can not find how to replace the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
