Question about HP Vs17 17" LCD Flat Panel Monitor
HP vs15 no problem
Pleeease help me!
Is it possible for me to open my HP vs15 monitor s i could check if there's something wrong with the power button?
Thanks!
  • Frank Zhang
    Frank Zhang May 11, 2010
    you want know how to open all cover?
    Sergeant:
    Champion:
  • 225 Answers
Please check first if your LCD monitor is still under Warranty period, if yes, then I recommend to bring the unit to authorized service center to properly diagnose & fix the problem, because if you open it yourself & probably broken its seal then the Warranty will be Void & other problem/s that may arise / found will no longer be covered by their free service / part replacement.
If no longer covered by a Warranty, then you can open it by yourself, by turning (counterclockwise) its lock screws to open its back cover & check the power button connections if loose/broken. regards
Posted on May 15, 2009
Im trying to connect my ps3 to hp vs15. i really need help!
HP VS15 model does not support HDMI cable input. (high definition multimedia interface) It only supports VGA (blue) analog signal only.
Hope it helps.
Oct 03, 2014 | HP vs15c Monitor
IBM 8303 DOESN'T SUPPORT MY FLATSCREEN HP VS15
2 steps:
1. plug the hp vs15 into another computer and see if it works, if not could be a bad monitor.
2. If you have the old monitor, plug it in to the IBM computer and in windows lower the resolution down to 640 X 480. Now turn off the computer and plug in the VS15 monitor. If resolution was an issue it should work now.
Hope this helps
Jan 31, 2012 | IBM Computers & Internet
I want to connect my playstation 3 to my hp vs15. But after doing a little bit of research i am asked to change my display mode in order to get video from my playstation 3. hence my question is how do...
You change the video resolution at the video source, in this case, your PS3, not at the monitor. VS 15 has 1024 x 768 60Hz Maximum Resolution, so your PS3 cannot be higher.
You need to google 'how to change PS3 video resolution' If the PS3 resolution is set to high, the VS15 will display Out of range/format/video not support.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
May 20, 2010 | HP vs15 15"LCD Flat Panel Monitor
Vs15 (Gray, Metallic) 15 in. Flat Panel LCD Monitor: you mash the power button and the light will come ...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 16, 2010 | HP vs15 15"LCD Flat Panel Monitor
No power when u plug in an turn on HP vs15 15 in. Flat Panel LCD Monitor.can u tell me how to open it up so i can check the switch
You need thin flat blade screw driver to crack open the case, it is almost the same as VS19, more likely to havebad caps with bulging tops, see pictures here: http://s807.photobucket.com/albums/yy352/budm/HP%20VS19D/
Mar 10, 2010 | HP vs15 15"LCD Flat Panel Monitor
Is it safe or unsafe to try to repair on your own?
You have 6 screws 4 hold the base on and 2 on the backside of speakers. From their you can open it.
If you still have the monitor that is.
Oct 24, 2007 | HP vs15 15"LCD Flat Panel Monitor
HP vs15 Flat Monitor
It depends what computer you have, and what version of Microsoft you have. for those of you with the Presario SR1650NX computer, here is the Latest driver: Click. For the earlier driver: Click.** to download drivers for you computer go to your computers company website (Gateway, HP, Compaq, Etc.).
**I Recommend downloading the older version first, and if it doesn't work then download the latest.
Oct 06, 2007 | HP vs15 15"LCD Flat Panel Monitor
Hp vs15, black screen, power light goes on and off like it is in sleep mode
Monitor is dead. The LCD inverter board probably went out and needs replacing. More than likely, it will cost you over $100 to get it fixed. It's better to spend the money on a new monitor.
Jul 13, 2007 | HP vs15 15"LCD Flat Panel Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
256 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
