How to get AMD athlon 3700 socket 754 engineering sample cpu run at proper speed
I wonder whether you can help me to get my AMD Athlon 64 3700 Clawhammer ( engineering sample 00 (es)Socket 754 to run at its proper 2400 speed. I have dried different bios with no luck and the bios at the moment lets it run up to 2220 with the fsb at 202 and on cpu-z it shows multiplier at 11 when it should be 12? I am running an Asus k8v se deluxe board and have 3gb ram. On the bios there is no way of adjusting the multiplier only core voltage Hz in in 100 steps and the FSB. So how do I acheive the proper speed of the cpu? Kev
  • pin_0018
    pin_0018 May 11, 2010
    ru Mobo should have a DP Switch there  r five Switches Check ur mobo manual and adjust the Switches according to that.
    Scholar:
  • 111 Answers
Here's a little history
http://compreviews.about.com/cs/pchardwarebasics/a/aaBIOS.htm
More advanced stuff
http://compreviews.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=compreviews&cdn=compute&tm=128&gps=215_11_1267_540&f=00&su=p284.9.336.ip_p504.1.336.ip_&tt=2&bt=0&bts=0&zu=http%3A//www.adriansrojakpot.com/Speed_Demonz/BIOS_Guide/BIOS_Guide_Index.htm
Some systems have "bottlenecks," where small overclocking of a component can help realize the full potential of another component to a greater percentage than the limiting hardware is overclocked. For instance, many motherboards with AMD Athlon 64 processors limit the speed of four units of RAM to 333 MHz. However, the memory speed is computed by dividing the processor speed (which is a base number times a CPU multiplier, for instance 1.8 GHz is most likely 9x200 MHz) by a fixed integer such that, at stock speeds, the RAM would run at a clock rate near 333 MHz. Manipulating elements of how the processor speed is set (usually lowering the multiplier), one can often overclock the processor a small amount, around 100-200 MHz (less than 10%), and gain a RAM clock rate of 400 MHz (20% increase), releasing the full potential of the RAM.
AMD also produced x86 designs which competed with Intel on performance rather than price. In January 2002 the Pentium 4 gained a lead in sales and AMD marketing responded by giving their processors numeric suffixes approximating the clock rate that an AMD Thunderbird (and by inference a Pentium processor) would need to give matching performance, openly undermining the "megahertz myth".
Posted on Jul 08, 2009
What can i use processor in this motherboard can i use 1.8 mhz
Processor speed 1.8 MHz is not the parameter for using this kind of motherboard. Upgrading or replacing CPU on motherboard is based on the socket CPU, and your motherboad support AMD® Socket AM2 Athlon 64 X2 / Athlon 64 FX / Athlon 64/ Sempron....
Aug 06, 2011 | ASUS M2N-MX Motherboard
Can you tell me why when i put CPU in my computer he give error? CPU is AMD Athlon 64 3400+ 2.4GHz socket 754.My motherboard is socket 754 Gigabyte GA-K8NE-RH. Problem is my computer or CPU?I take CPU...
The motherboard will support this CPU, with the F1 bios.
I can only advise, that IF your motherboard was working ok before you put the new CPU in, it must be the new cpu you bought.
If this is the 1st CPU you have tried, there is a chance the board is damaged
Jun 13, 2011 | AMD Athlon 64 3400+, 2.4 GHz...
I am using ASUS K8VMX motherboard with AMD Athlon 64 2800+ motherboard. Now my motherboard has gone bad. I want to change it. Suggest which motherboard should i use (754 socket)
Whatever board that is in a microATX format and has a 754 socket will do - they all had the same general hardware characteristics and requirements - so get the cheapest you can find.
Apr 17, 2011 | AMD Athlon-64 2800 CPU and Mother Board...
I have AMD Athlon(tm) 2800 64 Processor 2800+ 1.81 Ghz 1GB RAM I want to upgrade it to Latest AMD 64.Please let me know what is to be done?
There is a full list of AMD 64 processors at http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors.
The Socket of your CPU is 754 which means that the highest you can go is to a 3400+ at 2.4GHz.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
Nov 13, 2010 | AMD Athlon64 2800+, 1.8 GHz Athlon 64...
I am using amd sempron LE-1100 i want to upgrade to a gaming pc so that i can play the sims3. so if i like to upgrade to amd athlon x2 how to know my socket type. please help
Your socket is AM2. You can put any AMD processor that has AM2. If the processor is AM3 just upgrade the bios of your motherboard and it should work. If you need further assistance, just leave a comment. Cheers
May 24, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Cpu Models to upgrade Compaq Presario sr1920nx
CPU/Processor
  • Socket: 939
  • Supports the following processors:
    • AMD Athlon 64 X2 up to 4800+
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Cpu/Processor Type
Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Dec 22, 2009 | HP Compaq Presario SR1920NX PC Desktop
Cpu upgrade
According to the spec sheet on the MSI website, this motherboard will take up to a 3700+ Athlon. Check out the link:)
http://www.msicomputer.com/product/p_spec.asp?model=K8MM-ILSR&class=mb
Further testing is being done on this board, but here is the UPDATED CPU compatibility chart:)
http://global.msi.com.tw/index.php?func=prodcpusupport&maincat_no=1&prod_no=601#menu
Dec 30, 2008 | MSI K8MM-ILSR (MS6741030) Motherboard
Processor upgrade
Need to look at the motherboard specs along with the processor "Socket". It will usually be a 754 or 939 depending on what your motherboard says. I wouldn't try too fast and set yourself up for disappointment. I would upgrade the RAM before the processor.
Mar 22, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
CPU Upgrade-Which Sockel?
Here is some information may be useful to you. Intel processors Socket 1 169 pins 486 SX/DX Socket 2 238 pins 486 SX/DX/DX2 Socket 3 237 pins 486 SX/DX/DX2/DX4 Socket 6 235 pins 486 DX4 Socket 4 273 pins Pentium 60 en 66MHz Socket 5 320 pins Pentium 75 t/m 200MHz Socket 7 321 pins Pentium, AMD K6/K6-2/K6-3, Cyrix M1/M2 Socket 8 387 pins Pentium Pro 150 - 200MHz Slot 1 242 pins PII, PIII en Celeron Slot 2 330 pins PII Xeon en P III Xeon Socket 370 370 pins PIII, Celeron, Cyrix III Socket 423/478 423/478 pins Pentium4 Socket 603 603 pins Pentium4 Xeon PAC418 418 pins Intel Itanium PAC611 611 pins Intel Itanium 2 AMD processors Slot A 242 pins Athlon Socket A 453 pins Athlon, Athlon XP, Athlon MP and Duron Socket 754 754 pins AMD Athlon 64 Socket 940 940 pins AMD Opteron Conclusion: You can not upgrade beacuse Armada M700 has a pentium III processor with 370 pins. So the Socket 478 pinned pentium is not suitable. Advise: Try to exchange it with a new laptop or buy a used laptop for suitabl configuration
Oct 01, 2007 | Compaq Armada M700 Notebook
Computers & Internet Logo
514 people viewed this question
David Payne
David Payne
