Question about Behringer Pmp3000 16 Channel Audio Mixer
I have a behringer pmp3000 how do i select the setting to allow me to have mains on one side of the out and monitor on the other? I know the selector switch must be in a certain position, but which one, and will the channel- monitor 1 be the control for each channel to the output to monitor
  • Frank Allik
    Frank Allik May 11, 2010
    Im sorry I dont get the Q ...you have a sound board that has a stereo MAIN OUT and 2 monitor sends....what is it your tryin to accomplish?
  • Behringer Master
  • 5,603 Answers
You want the mon1/mono setting. The center position of the slide switch to use each half of the power amp seperately. Then fiddle with the controls BOTH in the strips and the faders to get desired result.
Posted on Jul 27, 2009
I'm Ziro. I need a part list for the main power supply board for behringer pmp4000 mixer, two transistors were removed from it and I need to know the part numbers of each in order to install them.
In my opinion, due to the physical appearance of pmp4000 and pmp3000 look the same, it will most likely also have a common circuit and parts list (at least, most).
Usually Behringer (and all the manufacturers), with the same series / sequence, using the same circuit, the difference is the number of channels only. You can compare the parts list on PMP3000 schematic, with your PMP4000.
PMP4000.
PMP3000
You can download from this link.
http://elektrotanya.com/behringer_pmp3000_sch.rar/download.html
Hope this helps.
Regards.
Oct 05, 2015 | Behringer Music
Our Behringer pmp 6000 just recently mysteriously lost both monitor 1 & 2 signals. Please provide some suggested resolutions? Is there anything other then the channel monitor level knobs and the main...
Try plugging in a set of headphones into each of the mon left and right. If the monitor sliders are up AND the channel monitor knobs are up you should be able to hear in ONE SIDE only of the headphones. If not, then you may have failed to power your monitor amp or speakers from the SAME receptacle as the mixer and this can result in ground bouncein building wiring that will blow out the driver chips for the mon signals.
Nov 01, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Hi Folks, I have the Behringer PMP3000 Europower Desk. now also have a studiomaster VPX15 Sub (Active 600W). Does anyone know what the crossover arrangements are on the PMP for the Mono out, and what...
There is no crossover arrangement. On the PMP5000 they have a tunable filter INTENDED to do low pass for a subwoofer. When selecting this mode for a subwoofer The frequency of the low pass filter can be set between 30 and 200 Hz. This feature is NOT available on the PMP3000.
There is nothing related to a crossover in these amps other than what is mentioned above.
The MONO out is merely an analog summation of both the L and R channels.
Mar 06, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
When I plug in my XLR microphone to my Behringer PMP3000 it only works on the Main/Mon function not the Main L/R function, and when it is working it only amplifies through one speaker. WHY???
Check if the PAN control for that channel is set at 12 o'clock position.
You can "pan" the mic to either L or R speaker or anything between.
On the Main/Mon setting, the level sent to the Mon side is controlled ONLY by the Mon level pot for that channel.
Oct 04, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
We are having problems with a PMP5000 board. We have the switch setting on Mon1/Mono. We can get sound out of the monitor output, but the mono output is almost silent. Do you have suggestions for...
Do you mean the SPEAKER mono output or the top mounted 1/4 inch jacks?
The A side power amp is used to drive monitor speakers and the B side the mains.
All other connnections of speakers require amplifier OR powered/active speakers.
Aug 20, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Hello; I have a used Behringer pmp5000 mixer. The
Without knowing how you have your monitors configured it is hard to analyze what you have posted.
In brief, SW3 on the schematic that selects MAIN L and MAIN R in the upper position, MAIN and MONITOR in the middle, and bridged in the lower is used to configure the internal amps.
In the upper position, the amp power outputs come from the mixed stereo bus and are simultaneously controlled as a stereo signal by the MAIN slider.
In the middle position MAIN and MONITOR, the left amp receives the signal from the mix bus and is controlled by the MAIN slider. The MONITOR output from the other side of the power amp is controlled ONLY by possibly the "MONO" slider.
The schematics are hard to decode and what is needed is a signal flow diagram.
For my uses, I don't try to use splitting the power amps between mains and monitor but prefer to use the mains together with SW3 in the upper position (Note your 27 may be refering to the user manual designation for same switch). I then use another small amp from the 1/4 inch MONITOR jacks whcih are under control of the MONITOR sliders.
Please note that the MIX for these two MONITOR channels is controlled by the MON1 and MON2 knobs for each channel.
May 23, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
How to get the effects to work on the mixer
This is in general for Behringer mixers since you did NOT tell us a model number...
To use the effects you adjust the FX knob for EACH channel for the amount of the mic or input you want to send to effects from that channel. This is the "send" mix.
You dial in one of the effects based on the list near the effects selection window with the selector knob and the number will change and start flashing. You press down on the selection knob which will enter the new effects number and the number will be solid and not flashing.
Then there is a knob to select how much of the OUTPUT of the effects you want to go to the main and sometimes one for the amount to the monitors.
That is all there is to it. The effects can be gated by a foot switch input if you desire.
It is a good idea to include a model number as your thing is posted as if it is a PMP3000 mixer.
May 11, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
How do i get the effects to work? cant seem to get the effects to turn on, for behringer pmp3000
You have to select an effect, push down the selector knob to lock it in. You have to send signal to the effect by turning up the effect in the "strip" above the slider. You have to turn up the effect sent to the main below the effect window, and finally use the effect slider to control the amount of effect. There may also be a button to toggle the effect on and off near the effect number window.
Jun 24, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Finding a way to hook this up
Send main 1 out to your Crown. Jump Mon send to PWR am insert.
Mar 11, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Using Behringer PMP3000 to power monitors??
Using the mon out and the proper balanced cable follow the instrcutions found in the manual section 61.
Here is a link to the manual.
http://www.behringer.com/EN/downloads/pdf/PMP1000_P0566_M_EN.pdf
Oct 04, 2008 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer Pmp3000 16 Channel Audio Mixer Logo
161 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
