Question about Craftsman 20 Hp 42" Deck Lawn Tractor
2000 with kohler engine starter wont turn engine over.
)n the craftsman 2000 with the Kohler engine. The compression is so great that the engine has burned out 2 starters. The battery has been replaced also. It appears there should be a compression release.
    Sniper:
  • 57 Answers
Try adjusting the valves. Not an uncommon problem.
Posted on May 15, 2009
Starter kicks in but wont turn engine acts like too much compression,battery is fully charged
Very can be if it is an OHV engine that either the valves are needing adjusting or the decompressor has failed.
Most 4 cycle small mower engines have decompressors to help with the starting, These are only active at start-up and does not effect normal engine compression when running.
May 18, 2015 | Cub Cadet Riding Lawn Garden Tractor 25hp...
What to do? I have a craftsman GT 5000 with a 25 HP Kohler and it will run for about 10 minutes and then start cutting out and die. I have changed the fuel filter with no resolve. What should I look at...
Make sure the choke is coming off. Check the compression.Many times the head gasket may leak when the engine heats up. Also check for spark sometimes the magneto can heat up and quit after running a while. See if it will run if you prime with a little fuel, if so ,some of the Kohler engines this size have a fuel pump that could be failing. Check for vapor lock. It takes air and fuel properly mixed, spark and compression any of these missing the engine dies.
Aug 06, 2014 | Kohler Command Pro OHV Horizontal Engine...
Craftsman LT1000 riding mower hard to turn over
Make sure carb is not dumping gasoline into cylinder causing a hydraulic lock
Jul 29, 2014 | Craftsman Garden
2010 craftsman 46" w/ kohler 22hp engine, problem: starter solenoid chatters rapidly when switch is turned. starter does not turn. replaced solenoid w/ no change?
the solenoid chatters due to voltage drop. Check battery charge & condition, and check battery terminals and connection to ground and the solenoid.
Nov 08, 2013 | Craftsman Garden
Craftsman 42 " mower w/Kohler 18 horse engine clicks, but will not turn over.
my westwood tractor 1600hp will not charge the battery
Apr 17, 2013 | Craftsman Garden
I have 16 hp Kohler engine with a compression release not working,help.
i have a Kohler 16 Magnum opposed cylinder engine and it wont crank over with the spark plugs in it,battery and starter are both good,its an aluminum engine and i have seen several of the Kohler engines break the automatic compression release on the cam gear and they seem to lock up while trying to start,pull the plugs and the crank fine,Kokler is the most expensive engine i have seen and their parts are outrageously priced,old Kokler was a good engine,newer ones in my opinion are junk,i work at a small engine shop,i have seen new Kohler engines with a broken ACRs,i work at a second job,we got a new supervisor that worked for Kohler before her came to our plant,he said he worked customer service at Kohler and he heard complaints constantly from people using their engines and the returns were out the roof on their engines,what im saying is i wont ever but another Kohler unless itsm an old one,Thanks Tommy
Jun 06, 2012 | Kohler Electrical Supplies
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Kohler engine wont recharge on tractor
Either the stator went out or the voltage regulator is faulty and must be replaced
May 29, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
806 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
