Question about HP Pavilion dv7z Notebook
Pavilion dv7 laptop driver problem BSOD
Pavilion dv7 laptop driver for Hard Drive driver for XP, Geting a BSOD on install of XP SP2. That is why I need my driver for my Hard Drive. Problem.
  • tyson50 May 18, 2009
    Thank you but I solved it another way. I found many posts that people wanted to install xp but I said to my self "Vista is ok" Has SATA support built in, has 64-bit on my version that came with my laptop and lastly windows 7 is coming out before october 23 of this year (2009). So why not keep Vista, on.
    So the solution is first install the microsoft OS you want next the version of linux load on but when it sais something about the boot loader reright to the MBR (Master Boot Record) right to the partition! Should Work after that. The problem is that windows wants to be in control of the MBR and have its own boot loader so if you install it on first reright the bootloader on the partition of linux and linux will just add it self to the MBR. So Linux and windows can live on the same machine what a thought. P.S. Works with any Microsoft OS.
  • 696 Answers
DV7 is not designed for XP, to get around the issue you may be able to change the BIOS setting for the SATA controller to work in IDE mode(depending on the BIOS) or you can use the XP installer option to install a SATA/RAID driver during the installer boot sequence. To offer you this I will need to know the model # and Serial # on the white sticker on the bottom of your laptop or the make and model of the SATA controller.
Try the Bios option and reply back with the requested info if it's not a viable option and I will see if there is an XP driver available for your controller.
Chris
Posted on May 17, 2009
I can't install Windows Xp Sp2 For Compaq Presario Cq60 Model. a blue screen error occured after completing the files from cd to ram before entering lience agreement
You need to check your system ram or memory. If you have 2 system ram or memory unplug the other memory and install the windows xp sp2 again. If still having a blue screen try the other memory then run the setup again. Also if you have an extra hard disk drive you can test it that or plug your hard disk drive to the other laptop and run the windows xp sp2 using your hard drive. If you can install the windows xp sp2 on the other laptop that means your hard disk drive are good. If your memory and to the other laptop are compatible plug it and run the windows xp sp2 installer to see and to diagnose what are really causing problem. Have a nice day.
Apr 02, 2011 | Computers & Internet
How can i install windows xp when screen showing blue screen
Check whether you have installed the SATA Hard Drive driver using a Floppy disk. Some Computers needs SATA Hard Drive Driver before installing the Windows XP. Try using Windows XP SP2 disk.
Jul 01, 2010 | Compaq Presario 700 470024-192 Notebook
A7V600-X mb, Win XP SP3, microphone not working
Skip my reply above; didn't work. The BSOD is very erratic, so its hard to be sure. Try DLing the latest Realtek HD Audio drivers
May 05, 2010 | ASUS A7V600-X Motherboard
How to get software for downgrade from vista basic to xp sp2 oper
first you download a sata controller of your hdd because winxp sp2 will not support a sata controller after you finesh download the sata controller copy the installer of windows sp2 then compile it again to gother sata contraller. or just download a windows sp3 has updated inculded sata controller that is the easy process
Mar 04, 2010 | HP Pavilion dv6000z Notebook
My HP Pavilion dv7-1130us won't recognize dvd drive
it sounds like the drivers have gone missing for the dvd drive
you can try system restore or if you have Win Xp Cd
you can try a First Repair to fix the problem
Jan 31, 2010 | HP Pavilion dv7-1130us laptop
I install Windows XP mode and then Microsoft Virtual PC. The computer reboots after virtual pc installation and I then run Xp mode and find it wonderful. I will shut XP mode down and then reboot and my...
Try using the free and simply brillant Sun systems 'VirtualBox'.
http://www.virtualbox.org/wiki/Downloads
I am running Windows 7 Ultimate and could not implement Windows XP mode and MS VPC does not support USB devices: I have both Win XPPRO SP2 and W2003E running in VirtualBox with supports to all my existing USB devices including VGEAR DTV which refuses to works since Vista days and Native Windows 7 (eg. no drivers!).
Hope it helps!
Nov 01, 2009 | HP Pavilion dv7-1130us Notebook PC
SMART failure predicted on hard disk 0:
There is a big problem with newer conponents and Win XP versions prior to SP2. Especially with newer motherboards.
You have to make a bootable SP2 disk if you don't already have one. To do this use the slipstream proceedure specified on the Ms website. Many other websites describe the process with easier language.
Slipstreaming is a common practice now. Essentially, you copy your original install disk to the c: drive then download SP2 to C: drive then download the slipstream utility from MS. Running the slipstream utility then inserts the proper drivers (ide and HD drivers too) into the licensed copy you have. You then create a bootable disk from the slipstreamed files you have.
This approach is resolving alot of blue STOP errors and SMART errors.
ALSO, you want to make sure you are installing any drivers provided by the MB manufacturer AND Drive maker.
Good Luck
Jul 29, 2009 | Computers & Internet
BSOD when not doing anything
Typically this is a driver issue. See if you can start Windows in "Safe Mode" and look for conflicting drivers. The Windows SDK will help determine the BSOD issue if you copy the information doen. The SDK's are avaialble from Microsoft.
Apr 30, 2009 | Microsoft Windows XP Professional SP2
Windows os
Its true. the Bios or HDD driver wont allow you to install Win XP on it.. This BIOS is compatible with only Win Vista. The only easy way to do it is by creating 2 partitions while installing vista. once vista is installed- install XP with Dual boot and than format the vista partition.
Feb 04, 2009 | HP Compaq nc6000 Notebook
Compaq C733TU audio driver for windows XP sp2
i have compaq 772TUlaptop
i formated my laptop bt now want to download d audio from net
hw to do
Jan 21, 2008 | Compaq Presario 700 470024-192 Notebook
HP Pavilion dv7z Notebook Logo
208 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
