Question about HP Pavilion a450n PC Desktop
My hp a450n won't turn on. We had a thunder storm
My hp a450n won't turn on. We had a thunder storm with a huge boom and now my computer won't turn on. The green light in the back is flashing. Any ideas?
  • kurt_donakow May 15, 2009
    The computor was off and also the monitor at the time. It was 2am in the morning. I did have a surge protector and this was beeping.
  • HP Master
  • 3,267 Answers
Was the PC running when the storm struck? In that case changing the power supply knows as SMPS which is inside the cabinet needs to be replaced provided your monitor when independently connected to a power outlet, gives a display or says 'no video signal'...................sodeep
Posted on May 15, 2009
  • Sudeep Chatterjee
    Sudeep Chatterjee May 15, 2009
    I hope you recieved my answer, if not, her it is again. PC was shuutdown normally but the power switches wre not switched off. That means power was available to the SMPS only. You are lucky to have only the SMPS damaged only. Also get the fuses checked for the UPS & spike board..sodeep
Tv does not turn on, after a thunder storm.. tv was off during storm.. but heard a click as if I was turning off tv.. Blueray player , ok Direct tv box ok , all come on that was connected to tv... whi
during thunder storm, is your TV connected to wall outlet, if it so your set have a problem on power supply, you are lucky if is only a blown fuse.
Aug 06, 2014 | Televison & Video
A450N needs new monitor - what monitor specs are required?
Any monitor will do unless you are trying to get one with the built in speakers that you have. Just make sure the monitor has the same type of connection that you currently have (VGA, DVI, HDMI, etc).
Apr 23, 2012 | HP Pavilion a450n PC Desktop
I have a nintendo 64 that turns on and has sound but no video output. I have tried 3 different connectors including a gamecube one that has always worked with my gamecube and still does. Is there anyway i...
Well I think that the console might of had been damaged by lightning thats why when theres a thunder storm you should always unplug your consoles so they won't get hit by lightning I always unplug mine when theres a thunder storm. Well the sound module inside of the console is broken then so you could send it into console solutions then they repair old systems too.
Aug 16, 2011 | Nintendo 64 Console
We had a thunder storm a few days ago and that we lost power and that the pc shut down by it self so the next day we try to turn on the pc so it won't turn on please can you help us
Make sure that all the plugs are plugged in. Try a different outlet, if it's plugged into a surge protector make sure that it didn't trip. Or if is plugged into a regular power strip press the reset button on the side of the strip. If that doesn't work there usually is a fuse inside the PC that might have blown.
Jun 05, 2011 | HP Pavilion a6700y PC Desktop
I have a HPp2081 and last night we had a severe thunder storm. My computer went off and when it came back on it had a White block with OSD Lockout on it. I don't know how to fix this or get it off my...
Turn the monitor off.
Unplug it from the AC power.
Reconnect it, turn it on, and see if it returns to "normal".
Do you have house-insurance that covers electrical damage from lightning/thunder storms?
Jun 23, 2010 | Computers & Internet
HP a450n stays in a loop after thunderstorm
This often happens during a storm and usually is quite an easy fix.
Remove the power cord, from the back of the computer, with the back of the computer facing towards you, on the right hand side there should be 2 screws top and bottom, remove these screws and take off the side panel.
Inside the case, on the motherboard you will see a large battery, take that battery out and leave it out for 30 minutes.
Now, remove the system memory, the memory will look like this >>>>>
Just unclip the memory, get a clean, dry, soft paintbrush and clean the brass contacts on the memory with that.
If there is any dust on the slots that you took the memory out of clean them also.
Wait for 30 minutes, reinsert the memory making sure it clips into place properly, put back the battery, the side panel, the power cord and power the machine on.
When the system boots up you will get a CMOS error, don't worry about that just go into the BIOS and set the time and date, save the changes and exit the bios, the computer will restart and hopefully boot into Windows.
If you need anymore advice please post back.
Good luck.
Aug 03, 2009 | HP Pavilion a450n PC Desktop
My hp a6130n desktop computer won't turn on after a lightning storm. The power supply is good (the little green light in the back comes on) the switch is good - tested it, so I wonder what is wrong - is it...
i got the same problem accept it didnt involve lighting storm thunder when i turned it off then i try turning back on it would start any help seems like the motherboard is fine the lil green light on back is on also can figure the problem help plz?
Jul 06, 2009 | HP (D7580-60003) Motherboard
THUNDER 5601 WHEN VEHICLE TURNED ON, SUBS BOOM, THEN WORKS OK. ALSO WHEN RADIO TURNED OFF
If the amp produces no boom with no signal input cables connected, I'd suggest using an LOC.
Let me know if you have any other questions.
Sep 30, 2008 | MTX Thunder 3401 Car Audio Amplifier
HP Pavilion a450n PC Desktop Logo
361 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
