Question about Zanussi Washing Machines
Zanussi washer washers,drians but will not spin
Zanussi washer washes,drians but will not spin where do you find the carbon brushes or advise anything else to check
  • 95 Answers
The transmission is belt driven so carbon brushes cannot be the issue. most likely it is a slipping or loose belt remove lower rear panel and check belt tension also check condition of the belt. In order to shift into spin there is a solonoid that activates the transmission you should be able to hear it click. if it just hums it may need replacment.
Posted on May 15, 2009
Zanussi fs1455w not spinning fast under load. Without anything in the drum it spins fine??? Tried all speeds with the same result. Any ideas???
May be not pumping efficently. when the spin starts the initial rush of water floods into the drum from the clothes a build up of water under the drum causes a braking action on the drum and slow spin speed.. look for partial blockage in pump chamber hoses or under sink if a spigot connection. probably not the belt as it would throw off a loose belt. Check it anyway. if non of these check carbon brushes they may on the verge of failure.
Jul 23, 2010 | Zanussi FS1455W Front Load Washer
Washer won't do anything. was washing a large comforter and the washer stopped working in the middle of a spin cycle. water did drain. now won't turn back on...no noise or anything. fairly new washer only...
If there is any voltage on the power group, try it temporarily with another device, if there is a control light on the display and it burned then read this suggestion.#
Its written by Hitachi but its on all kind of brushes made by other brands to find .
Carbon brushes are one of the most commonly replaced power tool parts. This is because carbon brushes are wear items, meaning that through friction and use they will gradually wear away until they need replacing. Worn brushes are a common causes of intermittent motor function, reduced electric braking and reduced motor power. A worn-out brush will often be worn down near to the wire lead and can be cracked, pitted, or burned. When replacing carbon brushes, be sure to inspect your armature for burns, cracks, or other damage which can indicate larger motor problems. [ NOW COMES THE IMPORTANT THING what i suggest ]
This Brush will pop out a pin when the Brush wears to a certain length.
It is advised to keep an extra set of these brushes on hand at all times
Jun 30, 2017 | Maytag Washing Machines
Wont spin renewed carbon bushes and new motor ,belt okay.can you advise where the electronic detection device is on the machine,how can it be repaired
Usually located at bottom rear left of washer.
If not there, then located at top front right of washer together with timer control.
May 22, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi Turbodry 1200 spin problem
if this washer is used alot then it will more then likely be the carbon brushes which u will need to take the lid off undue 4screws out where it joins front to the back screws at the back to the bottom and 1screw either side of the bottom where the panels join together behind a little cap which will have an hole in the middle of it to get it out u will then be able to get to the motor to replace the carbon brushes
Nov 22, 2008 | Zanussi ZJD1219 Front Load Washer / Dryer
No spin
Your problem is that the carbon brushes on the motor have worn out and need replacing.. eaisly done
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
My washer wont spin
on the motor there are what you call carbon brushes.. these wear out over time, this then the motor stop spining check and get back to me . cheers doc
Nov 20, 2007 | Zanussi FS1455W Front Load Washer
Washing Machines Logo
313 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
