Question about Bang and Olufsen Beocenter 9300 Shelf System
Where can I buy speaker stands for S45 B&O system and also antenna for beocenter 4600. Circa 1977
  • 122 Answers
S45 speakers are from the late 1970s so unlikely to find stands.4600 can use indoor aerial with either 300 or 75 ohm connection.
Posted on Jan 11, 2010
Hi 'deejayes'..(re: message on 15/5/2009)
I do have a pair of brand new S45 speaker stands which are in their original box if you are still interested. I bought them for my own Beocenter 4600 music system which has smaller S40 speakers, so I didn't have any use for the S45 stands.
If you may wish to contact me my e-mail address is:- ron_more@msn
By r100ram on December 7, 2010
Posted on Dec 07, 2010
Hi, I have a B&O beocenter 1800 with a really load hum on the right hand speaker. This occurs on both radio and turntable. I have swapped speakers and cables and hum stays with RHS speaker output
this old timer probably has an output amplifier fault.with a circuit diagram any competent engineer shoulb able to locate the problem with the turntable removed access is easy and so is replacing parts
Nov 19, 2013 | Bang and Olufsen Audio Players & Recorders
Beocenter 7007 lights but no power
It is likely the audio output ic has failed, check the speaker wires for shorts, if okay! you will need a professional to take care of this.
Mar 21, 2012 | Bang and Olufsen Beocenter 9300 Shelf...
Our beocenter 9300 will only play at a low volume (of about 4 bars). You can increase the volume a bit, to about 8 bars, but not for long. The volume drops to about 4 bars in just a few seconds. What is...
TRY REMOVING THE SPEAKER CABLES AND LISTEN ON HEADPHONES,IF THIS WORKS THEN SUSPECT SP WIRING BUT MAY STILL BE AN INTERNAL FAULT IN UNIT EITHER OUTPUT OR P SUPPLY.
Sep 09, 2010 | Bang and Olufsen Beocenter 9300 Shelf...
B & O Beocenter 4600: The record player won't spin
the turntable wont spin unless a record is on the platter,the centre 45 adapter weighs the record to determine 33/45.try pressing 33 and turning the platter by hand(remove expensive cartridge first!),if it starts to spin the motor leaf switch is at fault.is the belt in position.the motor pulley can become unglued.
Jan 08, 2010 | Bang and Olufsen Beocenter 9300 Shelf...
I have a Bang & Olufsen Beocenter 9000 with a missing CD spindle
You might be able to get one from online parts shop CPC, they stock B & O parts. You can worry about if you can fit it when you've got one!
Dec 24, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Connecting a sonos 90 to BO 8000 active speakers
Does your sonus system has pre-out? you can directly connect one single rca cable to each output into the speakers. make sure, each speakers is set to left and right each channel. these switches can be found above the rca input of the beolab 8000 next to the power link input. You have to understand that by using powerlink source cable is ideal only for other bang&olufsen equipments......however, there are other options, if u don't have a pre-amp output of your amplifier, you can also modify the speaker out of the amp, thru a conversion cable available from bang & olufsen, with an rca cable left and right channel, without interfering with the powerlink.
Apr 03, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Trying to change speakers from B & O to BOSE
All you need to do is to measure or look up the impedance of the speakers on the Beocenter 9000. Most speakers are either 4 or 8 ohms. Now measure or look up the impedance ot the Bose speakers. If the Bose speakers are the same or a lower number than the Beocenters, you are good to go. But, if the Beocenters speakers are a lower number than the Bose, then you should not switch speakers.
Nov 20, 2008 | Audio Players & Recorders
Bang & olufsen stereo unit 9300
You probably burned the speakers.If you have the multimeter check the spekers for the resistance.It has to be 4 or 8ohms otherwise they are burned.And you have to check voltage on the amp connectors for the spekers.if there is any DC voltage presens the amp is also burned
Feb 18, 2008 | Bang and Olufsen Beocenter 9300 Shelf...
284 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
