Question about Panasonic DVD-RV31 DVD Player
Marantz dv4300 dvd player only plays cd's
Hi as i stated the very expensive player only plays cd's if it cant be reset do you know where i can buy a new lazer from at a resonable price?
Thanks
Will the Panasonic DVD RV-31 play DVD+RW discs. I have tried and it justs stops
Posted on Nov 07, 2009
    Brigadier General:
  • 4,090 Answers
Have you used a cleaning disk to remove dirt from the scanner eye?
Posted on Aug 19, 2009
I have Marantz Sa7s1 cd player it plays cd for a couple of tracks & then it stops & distorted noise comes into player it skips sometimes
If it does all that stuff then, you need to take it back or exchange it. If you like the company just exchange it, if not buy from some other company.
Oct 27, 2016 | Marantz Audio Players & Recorders
My cd-48 sometimes gives disc info but reads no disc when play is pressed???
i found my dads Marantz CD-48 on the attic and had the same problem. Some CD`s the player was able to play instantly others not, getting the Error Message after trying to read the disc. My problem was solved after i opened it up and cleaned the linse of the player with a cotton swab.
Mar 10, 2014 | Marantz CD-48 CD Player
A cdr630 twelve years old will not record on any blank discs optical fail on maxell tdk and all brands.do you know what discs i can buy for this machine.marantz state discs with a green dye but i cannot...
The manual states that 74 minute 650MB 1-4X disks run best; my machine would not burn anything I had, eventually I found 650MB crrw's on ebay for as cheap as 2 cents a piece, I have a fair number of them and so far every single one has worked. Imation 800Mb cd's seem to work 80% for me.
May 20, 2010 | Marantz CDR631 CD Recorder
Remote not working on Marantz 63cd. Tried
check the back of your marantz player, some old marantz products have a buttom at the back saying system or intermal, if it is on the system side, the remote will never works.
May 06, 2010 | Marantz CD-67 SE CD Player
No sound. Cannot read DVD's
Take it to the service center. If it is within the warranty period, you will not be charged otherwise they will take a service fee (min. charges) plus a part replacement (if required) fee.
Many service centers do not charge the min. service fee if there is a part replacement. However i suggest you ask before you give it to them. Another thing that you could try is to run a dvd cleaning disc in your player. However this solution has never worked for me in extreme cases. Yours is an extreme case.
Last but not the least to prevent future problems, always keep a DVD or CD disc inside your player as it covers the lens and prevents dust from harming it.
Sep 28, 2009 | Marantz DV4300 DVD Player
Marantz pm 15 s1 amplifier and marantz sa15 s1 Cd player
There really is no point in  connecting the two components with an optical (=digital) cable, if you didn't want to use the SA-15s DAC- and analog output section you might aswell have bo bought the chiepest one you could find...
To get better sound than the SA-15s analog outputs can provide, you would have to spend a load of money (not as much as for the SA-15 but quite a bit) on a DAC - and the DAC would only work with CDs, you would still have to use the SA-15s analog outputs to listen to SACDs.
So in conclusion:
-Use the SA-15s analog outputs
-If you have other digital sources that you want to use - if you care about their sound quality - you can sell/return the SA-15s, buy the chiepest CD-Player you find (only look and feel matter) and spend the rest on a good DAC. (note: SACDs won't play on this setup)
I'm using a PM-15S1 with a DAC (Apogee Mini DAC, Studio-Equipment, nominal price ~1000$, got mine 2nd hand for 400€ ) myself. A DAC is usually the better choice over an expensive CD-Player - especially if you've got other digital sources (PC, ...) - but you'll probably lose a lot of money if you sell the SA-15, so think about it (IF you're still thinking about it, I realise that your question is 8 months old...)
anyway... have fun with the PM-15, it sure is beauty
Jan (Hamburg, Federal Republic of Krautistan)
Jul 01, 2009 | Marantz PM-15S1 2-Channel Amplifier
I cant play newer dvds why ?
depending how old the player is it might not be able to read dual layer discs
Jun 07, 2009 | Marantz DV4300 DVD Player
Laser is malfunctioning on my Marantz CD Recordable DR6000
the laser in your DR-6000 is exactly the same as what's in the philips cdr-775 and cd-r-770.
a brand new laser for these are very hard to get hold of and are very expensive. personally i would look out for the above philips models on ebay for less money then take the whole mechanism out and unscrew the servo board and then fit the marantz servo board in place of it and fit it back into your recorder.
i have done this on numerous occasions with no problems.
hope this helps.
Feb 26, 2009 | Marantz DR-6000 CD Player
Marantz DV-6500 problem
Could be the laser Try cleaning it and if not Try and get it repaired Unless you wan't to buy a new one
Aug 03, 2007 | Marantz DV-6500 IN STOCK DVD Player
DVD playback problems
Did you buy these DVD's out of the country? Are they burned? did you pick English and the United States of America when you set up the dvd player? Try unplugging the player for an hour, plugging in and resetting everything up
Jun 03, 2007 | Zenith DVT216 System
Panasonic DVD-RV31 DVD Player Logo
93 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
