Question about Zyxel P660HW-D1 Router
Laptop dosent recognise perlico router
When i set it up worked fine then tried to install second laptop and
it woul not work when went back to first one stopped working to,
only power light and dsl light on router is on powered up ok and phone linked to splitter ok shouls other lights be on as well
  • 3 Answers
Hi Newross,
Is the dsl light is on the modem, no, if not , you need to login into the modem to switch on the wireless on the modem.
Just tell me what is the make of your modem i'll tell you how to actv wlan or elase ring your bb support.
Cheers......
Posted on May 31, 2009
Please tell me how To Open A Perlico Nat Type ??
Thanks
Posted on Dec 15, 2009
Hi, I am not sure if this is my problem but there seems to be a problem with the network key on my laptop. We are using a belkin N150 router and in the last 3 months or so have been having problems getting...
I think resetting the router to the factory defaults may fix the issue. Generally, after resetting to defaults, the router works fine, however, you have to setup security key etc.
First, to reset the router to factory default setting, press and hold the reset button for few seconds (It is at the back of the router). The LEDs will then blink and the routers factory settings wouls be restored.
Please note that after RESETTING THE ROUTER to defaults, ALL SETTINGS WILL BE LOST AND YOU HAVE TO RECONFIGURE IT. Generally, after hard reset you get the connectivity, however, you have to make the connection secure etc.
Please, refer the product guide/manual and make configurations as per the details provided by your Internet Service Provider (ISP).
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Jan 17, 2011 | Belkin (F5D7230-4) Router (587009)
Network is "Hidden"
Try a router reboot.
1. Unplug the Router
2. Shut down and restart the laptops, unplug the XBOX for 20 secondes even though its working.
3. Replug the router.
If this doesnt work you can try resetting the router to the factory settings.
Follow the link below for step by step resetting procedure.
http://www.geckoandfly.com/5890/reset-d-link-router-factory-settings-and-default-password/
Jun 13, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
I set up my laptop using a Belkin wireless router, and it is o.k. thro ethernet by does not recognise wireless when I disconnect the ethernet cable!!
Well the best shot is to reset the router back to factory by pressing the reset button for 10 seconds then it will flash a couple of times. then see if your laptop can connect to the router, If that doesnt work let me know
Nov 22, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I hav a linksys router wrt54g my computer and laptop work fine but my cell phone doesnt unless i remove security from my router
Some older mobile phones don't recognise some of the newer security settings (WPA2, for example).
It might be worth trying a different type of encryption (WPA/PSK or WEP) to see if these work better - obviously this would mean having to reconfigure the wireless connections on the computer and laptop.
Hope this helps.
Jan 21, 2009 | Linksys Wireless-G WRT54GS Router...
I have to unplug the router power/turn back on, 4 laptop to work.
Try using 128 bit hex code. You put in a passphrase and it will scramble it into 13 pairs of letters and numbers. Use that instead of WEP. (192.168.2.1 in the address to get into settings for router, default password is blank)
Dec 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My hcl laptops sound dosent work
if its says that "no audio d3evice found " then your laptop's audio drivers are missing
try driver disk
and reinstall audio drivers(sound card driver)
and this will re install your audio driver and your laptop can recognise sound card
Dec 12, 2008 | Computers & Internet
I have a laptop running vista and I Cant connect to linksys wag160n wireless router. Go through set up fine, and laptop recognises network but when I try to connect it wont. Tried resetting but to no...
Is the router for your use only or for a lot of people, if it's your own dedicaced router, simply reset it by the button on the back or the router should solve your problem.
If not working, by the router config; usually accessed through your browser, typing in the adress 192.168.1.1, find the security menu, and the MAC filtering option, deactivate it, and retry.
If always not working, we stay here...
Nov 29, 2008 | Computers & Internet
Intermittent Enabling
First you can try to uninstall and reinstall the driver of the wireless adapter on that desktop. Unplug and re-plug the wireless card. If it is a wireless PCI card, make sure the antenna is tightly screwed on. Install just the driver of the wireless card and not the utility/software that came with it. You can also try to change the channel on the wireless router by going to the router's user interface. If you're on channel 6, choose channel 11 and save the settings. Then power cycle the router, unplug the power for 30 seconds then plug it back in. Check now if you can connect wireless.
Oct 29, 2008 | Linksys WRT160N Wireless Router
Router gets disconnected
If you know how to open the setup page of the router, look for MTU. Normally it is set to Auto with default size of 1500. Now set it to manual and change the value to 1463 and save the changes. Power cycle the router by unplugging the power for 30 seconds then plug it back in. Observe your connection if it keeps on dropping.
Another is you need to isolate the problem if its the router or the modem. Try to connect your PC directly to your modem and observe if it does the same thing. If it does the same problem, call your Internet Provider to fix the modem.
If the problem still persist on the router after changing the MTU, try to update the Firmware of the router and hard reset it by pressing the reset button for 15 seconds then power cycle it.
Jul 24, 2008 | U.S. Robotics (USR8200USR8800KIT)
Wireless router keeps loosing connection
go to wireless device and re-configure it
Jun 14, 2008 | Dell Wireless 2350 Router
Zyxel P660HW-D1 Router Logo
484 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
