Question about Whirlpool GGQ8831L Gas Dryer
Heat cycle stops/
I have a Whirlpool gas dryer, it starts up fine, it will heat for approximately 10-15 minutes and the flame goes out. After a cool down period of 20 minutes or so, it starts up again and the same repeats itself. I have cleaned out the duct and the whole dryer itself, and I have replaced the 2 thermostats , but the problem persists, can you tell me what the problem could be.
Thanks, Tony
    Scholar:
  • 85 Answers
Problem is your gas solenoid coils. When they get worn they will open til they get out then shut. They will need to be replaced.
part nos 694540 and 694539
Posted on May 18, 2009
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
No heat while drying
If this is a gas dryer. It's possible that the solenoid gas valve has gone bad. One way to determine this is by do a dry cycle and listen to the gas and flame to start. It shoudl sound like a flame starting on a regular stove top. Once the flame starts you can hear the flame. If the flame stops in less than a minute that is an indication that the gas valves has switched off. You need to have the solenoid valve replaced.
Mar 01, 2011 | Whirlpool Dryers
When my mdg 6000bww is turn on heating element glows, flame ignites, then flames goes off within 5 minutes. After waiting approximately 15 to 20 minutes, until it seems to cool down can restart and goes...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Hi i have a whirpool gas dryer that all works fine but after about five minutes the heat will stop and it will just blow cool air. I can stop it and restart and everything starts and works fine and after...
The gas valve coils are closing the valve or the flame sensor is defective. The coils are the most common problem.
There are 2 on top of the gas valve. Turn off the gas and power. Remove the front panel by opening the top lid and then remove the screws from inside the front panel in the top right and left corners.
Nov 09, 2009 | Whirlpool Dryers
Dryer starts with heat. After 10-15 minutes, when dryer calls for more heat, here a metal clicking noise, flame does not ignite. When it's clicking, I can look down the back from the top and see a glow....
Your gas valve coils are defective. Part #694539 and 694540 are required. Once the coils get hot they collapse internally and the gas valve shuts off. This is a common problem when valve coils get weak from use.
Nov 09, 2009 | Whirlpool LGQ9857L Gas Dryer
Dryer heat shuts off
Hello, reading between the lines I'm going to assume you have a gas dryer. This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Jul 24, 2009 | Whirlpool Dryers
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Dryer flame on magtag wont stay lit. Pilot flares up but no flame
Thermocouple is probably bad. The pilot burns and heats a sensor which tells the CPU that the Flame can start, and the thermocouple heating up changes voltage with increase temperature and tells the CPU that the Flame is burning OK. If it is defective, there is no voltage change and the CPU assumes that the Flame didn't start for some reason, (Gas only!) and turns if off for safety. Over and over xx times.
My .02
Good Luck!
Mar 26, 2009 | Dryers
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Whirlpool GGQ8831L Gas Dryer Logo
203 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
