Question about Compaq 187498-001 Motherboard
CPU performance, compatible with i815E (Socket 370)
Get low
I want to upgrade my processor , how can i figure out a compatible processor for my aspire ?
download and install this software ..and it will map you all the components that you have inside it ..including the cpu ..and the socket it has ..and all cpu made for this kinda socket ...(you will find out in it ) ..will be compatible ..or ...get to the support site of Acer ..and ask them the exact model of the cpu that will fit and be compatible with your laptop ..
here is the program ...
http://www.mediafire.com/file/mezeoyv1z41/everest.rar
and here the support site where you can write them ...
http://support.acer.com/us/en/default.aspx
Have a nice day !
Mar 16, 2011 | Acer Aspire 5720 6497 Laptop
How many extra usb circuits are there on my ibm 09k9982-011 mother board
IBM 09k9982 011 ATX MOTHERBOARD P3 11s19k5609z 1N0Z9131W3C Netvista Socket 370
Condition: Used - pulled - working
Content: 1 Motherboard only
Compatible part # 06P2525 01
FRU 09K9982 , 89P8010
Chipset Intel 815 - FSB 100/133 - 2x Dimm PC100/PC133 - Agp 4x - 3 PCI - 2 USB
IBM 09K9982 Netvista Pentium III Moederbord.
Socket 370 Mini-ATX.
Intel 815 chipset.
2x Dimm pc-100/pc-133
Agp-slot (4x)
3x PCI
2x USB
Sound and Video on-board.
To use with : FOR IBM Netvista Socket 370 , 6648-TAU
hope this helps
Dec 11, 2010 | IBM (09N5424) Motherboard
Mv43 v3.1
This motherboard supports socket 478 cpu. This would mean it only supports Pentium 4. The Pentium 3 is compatible for a socket 370 motherboard.
So you won't have much luck.
Please rate this solution if you find it helpful.
Jun 15, 2010 | Shuttle MV43N Motherboard
Hi dear can this motherboard suport intel pIII
Here are the specs. to this motherboard Product Details Intel 810E Chipset, Socket 370, Compatible Processors: Intel Pentium III Specifications Key Features Chipset Intel 810E Compatible Processors Intel Pentium III Processor Max supported CPUs qty 1 Socket Type Socket 370 Memory Number of Memory Slots 2 x DIMMs Audio / Video Video Out Ports 15 Pin D-Sub VGA port x 1 Other Features Package Qty 1 Chassis Type Desktopso to your queston... Yes it supports Intel PIII have fun >.<
Feb 25, 2010 | Dell (002TR) Motherboard
Soyo SY-7VMA-B -supports P-3 tualatin (.13u) CPU's?
when looking for a cpu for the socket 370, be sure to NOT get the socket 370 cpu that is made for servers.
this type requires a motherboard made specifically for that type cpu.
use a search engine to find out how to tell if it is a socket 370 server CPU, there is not enough space here for me to explain it.
in that search you will also find out how to determine the answer to your question about cpu's supported by that motherboard..
most socket 370 based systems run pretty well, so you have a good machine there, and it's worth your time to keep it running, and to upgrade it.
Nov 07, 2009 | Computers & Internet
Cannot use intel pentium processor
you can only use socket 370 (Intel Celeron/Intel Pentium III) processors on that motherboard. Your maximum cpu speed is set by the bios.
Feb 19, 2009 | Gateway PGA370 E139761 DIMM Motherboard...
List of cpu support for pga 370 motherbord
The 810E Micro-ATX can only support the following processors
Intel Pentium 3 / Celeron
Jan 31, 2009 | Intel FC-PGA2 Tualatin Adapter for Socket...
CPU Upgrade-Which Sockel?
Here is some information may be useful to you. Intel processors Socket 1 169 pins 486 SX/DX Socket 2 238 pins 486 SX/DX/DX2 Socket 3 237 pins 486 SX/DX/DX2/DX4 Socket 6 235 pins 486 DX4 Socket 4 273 pins Pentium 60 en 66MHz Socket 5 320 pins Pentium 75 t/m 200MHz Socket 7 321 pins Pentium, AMD K6/K6-2/K6-3, Cyrix M1/M2 Socket 8 387 pins Pentium Pro 150 - 200MHz Slot 1 242 pins PII, PIII en Celeron Slot 2 330 pins PII Xeon en P III Xeon Socket 370 370 pins PIII, Celeron, Cyrix III Socket 423/478 423/478 pins Pentium4 Socket 603 603 pins Pentium4 Xeon PAC418 418 pins Intel Itanium PAC611 611 pins Intel Itanium 2 AMD processors Slot A 242 pins Athlon Socket A 453 pins Athlon, Athlon XP, Athlon MP and Duron Socket 754 754 pins AMD Athlon 64 Socket 940 940 pins AMD Opteron Conclusion: You can not upgrade beacuse Armada M700 has a pentium III processor with 370 pins. So the Socket 478 pinned pentium is not suitable. Advise: Try to exchange it with a new laptop or buy a used laptop for suitabl configuration
Oct 01, 2007 | Compaq Armada M700 Notebook
Compaq 187498-001 Motherboard Logo
107 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
