Question about HP Office Equipment & Supplies
HP LASER JET ERROR 49
EVERY TIME I TRY TO FAX SOMETHING IT GIVES ME THE ERROR 49.. I NEED TO KNOW WHO TO FIX IT.. IS A HP LASER JET M2727NF.
Http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3377075&prodTypeId=18972&prodSeriesId=3377075&objectID=c01571503
Posted on Jun 23, 2009
HP COLOR LASER JET 2605 PRINTER 49 ERROR MSG DISPLAY SOLUTION
49 errors are most commonly caused when the printer receives a print job with commands it does not recognize. You can try updating the firmware as this will often resolve the error. Go to HP's website to find the most recent firmware, however this model is fairly old and likely the firmware update will be fairly old.
Sep 25, 2014 | HP Laserjet 2605dn Workgroup Laser Printer
Hp laser jet m1213nf mfp fax storage memory full
hp laser jet professional m1213 nf mfp fax error repot storage full
Aug 11, 2011 | Panasonic KX-FHD331 Plain Paper Thermal...
I HAVE A HP LASER M2727 PRINTER WE CANT MAKE FAXES WHERE RECV. ERROR49 CAN YOU HELP US?
If you are getting a 49 error when you receive faxes you need to reset the machine and then check to ensure that you have the current firmware installed on the machine. If you print the config page from the information menu it will have the firmware revision listed. Then check HP's website to compare versions. To reset machine, go to service, and the to restore factory defaults. You will need to reprogram your speed dials and machine information after this.
May 06, 2011 | HP Laserjet M2727nf Multifunction Printer
I am getting Error 49..turn off and turn on error again and again from HP 2605 Color laser jet printer. Plz help.
It's a firmware error.
Do ALL your print jobs give this error. If it is just one job that causes the error, something is corrupted with the software.
If every print job causes the error, it's the printer. Try printing after removing DIMMs from the printer. If you can try plugging the printer into another port on the computer or router.
When all else fails, go to www.hp.com/#support and download the latest firmware and install it.
By all means READ the directions first.
Jan 31, 2011 | HP LaserJet 2605dn Printer
Error 49 when faxing
Internal embedded firmware error. Turn power off for 30 seconds. Power on. If problem is still there contact HP. I don't know how technical you are, you can go to www.hp.com/support/ljm2727. Also there should have been a support flyer that came in the printer box.
May 24, 2010 | HP Laserjet M2727nf Multifunction Printer
Error 79 hp laserjet m2727nf mfp; error 49 hp laserjet m2727nf mf
Recommended action 49 and 79 Errors, Turn off then on The product has experienced an internal embedded software error. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the product to initialize.
If you have recently installed a memory DIMM in the product, turn off the product, remove the memory DIMM, reinstall the DIMM to verify that it is seated properly, and then turn on the product.
If the error persists, contact HP. See www.hp.com/support/LJM2727 or the support flyer that came in the product box.
Jul 02, 2009 | HP Laserjet M2727nf Multifunction Printer
49.FF95 SERVICE ERROR
Please look on: http://www.fixyourownprinter.com/
There are much solutions of this problem listed ...
For example this (it see good):
http://www.fixyourownprinter.com/forums/printer/46157#1
HP Laser Jet 4250n by TLYNN (3/20/07 12:22 PM) reply + / -
Anybody know the error code "49. FF95 Service Error"
We can't get around this...
Firmware Error 49 by Stephen (edited 3/20/07 12:29 PM) reply + / -
It could be a bad job.
First disconnect it from your network and any PC it might be attached to.
Power cycle it, then if it goes to ready status try the built in test pages, do they work?
If the printer will go to ready status and you have a parallel cable with the proper connector, then you can try upgrading the firmware from a PC, you can also try to upgrade the firmware over the network.
More reading:
http://www.fixyourownprinter.com/search/forums?f=&q=49+4250
Re: HP Laser Jet 4250n by TLYNN (3/20/07 12:59 PM) reply + / -
Still won't go back to ready status. Turns on to the same error code....
Cold Reset HP Laser Jet 4250n by Stephen (3/20/07 1:03 PM) reply + / -
Try a cold reset, it will reset the JetDirect settings, but it's the next step.
Cold Reset:
Power off printer, wait about 5 seconds, then power it on, when asterisks start appearing on the display press and hold the check mark until all 3 lights come on solid, then use arrow keys to find cold reset and push check mark to perform the reset.
Re: HP Laser Jet 4250n by TLYNN (3/20/07 1:06 PM) reply + / -
Thank You so much for your help... but that didn't work either. Same error code showed up.
Re: HP Laser Jet 4250n by Stephen (edited 3/20/07 2:27 PM) reply + / -
Then you probably need to replace the formatter.
Do you have another printer you can swap parts with?
There is a slim chance the memory DIMM is bad, you can try it with the DIMM removed, if there is more than one DIMM you can try installing just one and then the other.
A 49 error indicates that the formatter could not understand or execute an instruction within a file or cannot interface with an accessory, DIMM, or EIO device. Troubleshooting 49 errors is done through process of elimination. First determine if the printer functions in a stand-alone mode then test communications to the printer.
These errors can be divided up into two categories; the associated troubleshooting depends on the circumstance the 49 errors are occurring.
A 49 error is always followed by Hexadecimal numbers, for instance, 49.00FF. The Hex code is a memory address. Most Hex codes are not documented.
Re: HP Laser Jet 4250n by dmzcompute (3/20/07 2:26 PM) reply + / -
I do not see anywhere where the printer has been disconected from everything. If you have not done so already disconnect every cable from the printer with the exception of the power cable and turn the printer back on and see if you get the error and if not report back here for further instructions.
Re: HP Laser Jet 4250n by Stephen (3/20/07 3:28 PM) reply + / -
You might also try disabling the embedded JetDirect.
To disable the embedded LAN port
Turn the printer power off.
Power on the printer and watch for the memory count to begin.
Hold down the SELECT (Checkmark) button, when you see the memory count begin.
Continue holding down the SELECT (Checkmark) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until EMBEDDED LAN DISABLED appears on the display
Press the SELECT (Checkmark) button. The printer then continues its power-on sequence with the embedded LAN disabled.
If this works the JetDirect built into the formatter is bad, you can either replace the formatter, or buy an JetDirect to install in an EIO slot.
Re: HP Laser Jet 4250n by Trev Pearson (3/20/07 10:08 PM) reply + / -
The only other thing to try, before spending money, is to get the network administrator to clear the print queue for that particular printer and then turn it on.
The theory being that a 'corrupt' print job is still in the system and as soon as the printer is turned on, that 'corruption' floods the network card with garbage which promptly goes 49.
If the printer comes 'ready', great. Then do a firmware upgrade. If not, then you will have to spend money on a new formatter.
Regards
Trev
Re: HP Laser Jet 4250n by roadrunner178 (6/21/07 2:09 AM) reply + / -
hi.
With a cold reset ,my problem solved.
try this as a first solution.
thank you
Re: HP Laser Jet 4250n by Anonymous (7/31/07 1:20 AM) reply + / -
THANK YOU WERY MUCH
FROM TURKEY
ZAFER
Jan 02, 2009 | HP LaserJet 2420dn Printer
Fax machine giving error message.
I thought you would help me with my problem not try to sell me a service plan. The problem is resolved and the machine is now working properly. If you want to know how it was achieved send $19.95 for the answer.
Dec 16, 2008 | Office Equipment & Supplies
510 people viewed this question
Seeker5211
Seeker5211
