Question about RIM BlackBerry ® 8830 Cellular Phone
App error 523, cannot reset
I've done everything to try to reset my Bberry 8830 - taken out the battery, memory card, SIM card, but it keeps coming up with app error 523. I know that the error stems from the Surreal theme following download of the 4.5 software, but I can't get in to dump the theme and get operational again.
  • butti420 May 16, 2009
    app error 523
  • Anonymous May 24, 2009
    have the download of the 4.7 soon after error 523 came up
  • 541 Answers
In my compurter goto C drive --> goto Program files --> goto Research in Motion --> delete vendor.xml file and reinstall the application after taking backup of the handheld.
Posted on May 27, 2009
  • Mila Sep 30, 2010
    if u have blackberry deskstop manager... hook up ur bb fone and run bb deskstop manager click up grade then wait until done.... automatic reboot plug it out ur usb fone... turn in off wait in secon press on then wait if success up grade...
My blackbery is showing app error 523 reset i keep pressing reset but it wont work. when i restart my phone it shows uncaught exception :index 12>=12 then again white screen and app error 523
Hi Akira,
This error can be caused by a few different things, including faulty third party software. Have you downloaded any apps lately?
Make sure you have BlackBerry Desktop Manager installed on your computer, then unplug the battery from your BB and make sure that it is not connected to the computer. Start App Loader, then plug the USB cable into your phone. Once the phone lights up, wait to see if it starts up and if the PIN appears on your computer (in App Loader). At that point, plug in your battery. The software should load, and you can remove the third party app. If you don't think it's an app causing the problem, you can try using the repair option in the Desktop Manager. Let me know how it goes.
Apr 12, 2011 | Blackberry Curve 8350i
App error 523 when it says reset what do i need to do? I hit reset and it goes through trying to reset and does the same thing over again.
BETTER MAKE "MASTER RESET" IN YOUR PHONE. THIS WILL FIX YOUR PROBLEM SOON.MAKE A BACK UP OF YOUR CONTACTS TO AVOID MISSINGS. THANK YOU . ADVANCE HAPPY NEW YEAR
Dec 31, 2010 | RIM BlackBerry ® 8830 Cellular Phone
App Error 523 Blackberry Pearl 8100
you need to wipe the device with JL commander and reload the software using desktop manager
Jul 19, 2010 | RIM BlackBerry Curve 8300 Smartphone
I keep getting an app error 523, i removed all of
try a factory reset:
How to reset BlackBerry Curve 8520 to factory settings: Press the BlackBerry key, Go To Options > Security Options > General Settings > Menu > Wipe Handheld > Scroll to Continue, press the Trackpad. it will reset your BlackBerry 8520 quickly.
Mar 28, 2010 | RIM BlackBerry Curve 8520 Smartphone
I have a Samsung F480 and I am getting my screen freezing and I can only fix it by taking the battery out. Is this a known fault of this model?
it is an issue not only to samsung phones but the other brands and model as well.
to give you an idea, the causes of phone freezes are.
1. firmware failure
2. low phone memory capacity due to some big files were saved to phone
3. errors on your memory card(i.e; not formatted through cp or formatted to pc instead of your cp formatting utility, etc)
4. deleted file system for your phone or relocations of its strings
5. deleted or modifications on the registry
6. other applications are running on backgrounds.
7. sim errors or the phone is having difficulty to recognize the it.
many more...
to help you fix the problem try to do the steps.
1. back up your phone files, examples are, contacts, messages, mms, notes, task, etc through your samsung pc suite.
2. switch off your phone.
3. remove your battery
4. remove your sim and memory card
5. reinsert your battery and switch the phone.
6. from your keypad menu, type this code*2767*3855# to factory reset your phone and erase or fix the errors encountered by it.
7. switch off your phone, reinsert your sim and battery and switch on play with it first by setting and configuring it and check.
8. if your sim doesn't give you any lagging or freezes, switch it off, and insert your memory card and check.
after a successful factory reset had taken place and your problem was not fixed.....troubleshooting steps.
note 1. if this doesn't fix your problem, try to remember what you have done lately to your phone.
example of it is, unlocking to all networks by the use of a patch, or reflash. if this was what you have done lately, try to go back to the one who unlocked it and have him reflash the firmware or the latest version of the firmware for your phone.
note 2, try a different sim check if lagging and pauses occurs. if not then your sim has the errors.
note 3, remove the sim and insert your memory card, if lagging and freezes occurs, there's also a problem in your memory card. you may want to insert it to your computer and run the virus scanner from your pc. and reinsert it after the virus scan and check.
note 4. after factory reset had taken place, and the phone restarts and without sim and memory it gives you the same problem, go to your nearest samsung service centers, you may be needing a firmware upgrades or firmware reflash.
regards..
Mar 03, 2010 | Samsung Cell Phones
How do i solve the APP Error 523 on blackberry tour. I have no password set, i have the OS version 4.7 on the blackberry device. The device loads and shows the error APP Error 523 and reset. Upon reset it...
I had this same problem it was from a third party application that I had downloaded. Go to blackberry.com, and select support and search your APP error it will walk you through a guide on getting it fixed--although your phone will reset back to default.
Sep 27, 2009 | RIM BlackBerry? Tour 9630 Smartphone
Blackberry 8310 app error 523
how can i fix error 523 on a blackberry 8830
Jun 26, 2009 | RIM BlackBerry Curve 8310 Smartphone
BBerry 8830 losing emails, call log and SMS log
The deleting of messages and/or call logs typically indicates a low amount of internal memory. The BlackBerry devices have what is called a Low Memory Manager that will kick in when the memory on the device gets low.
The quickest way to free up some memory is to perform a hard reset. This is where you remove the battery from the BlackBerry while it is still powered on. Leave it out for 30 seconds, then reinsert. Also, follow the steps in the link below to maximize the memory on the BlackBerry:
http://kitchbbtips.blogspot.com/2008/08/how-to-free-up-memory-on-your.html
Sep 28, 2008 | RIM BlackBerry 8800
RIM BlackBerry ® 8830 Cellular Phone Logo
522 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
