Question about Dell A525 Computer Speakers
No speaker sound
I have a dell computer, my speakers are desktop.  They will not work, I have tried new ones and still no sound.
  • gardie Dec 16, 2007
    Suddently my Dell A525 Computer Speakers with subwoofer went dead.
    It was preceded by a Crackling sound.
    - The blue light on the speaker is still there.
    - The connections are all O.K.
    - The sound settings of my Computer are O.K.
    - There is sound with any other replacement sound device !!!!
    It looks like this is definitely a hardware problem.
    I live on Curacao (N.A.) where there is no service for this device and I do'nt think it is feasible to send this abroad for repair. I realize that there are many possiblities what could be wrong, but I would appreciate if you could provide me with the most possible cause and location of the problem and what kind of actions could be taken
    The fact that power reaches the speaker (the indicatror light is on) may narrow the list of posibilities down.
    Thank you
  • NoBass4Me Feb 07, 2008
    I have same problem with my Dell A525 two speaker system with sub-woofer. Nothing but "hummm" coming out of the sub-woofer. It worked briefly then not at all.
    This appears to be a common problem with these speakers judging by the posts all over the net and seems to be that the Dell A525 speakers are defective. (Unfortunately, I bought mine through some wholesaler on eBay who must be reselling all of Dell's returns. I'm out of luck.) Be sure to get Dell to fix/replace before your warranty expires.
I have a dell computer my speakers want work
Posted on Jan 24, 2008
  • 425 Answers
Hi
first check connections or maybe you have a problem w/ your sound card. try replacing it.
Posted on Oct 16, 2007
4 Suggested Answers
SOURCE:
lenny297
  • 133 Answers
SOURCE: Sound Problems on my Dell
It should be having onboard sound card, check from Bio's setup whether the Audio is ON. also check in control panel sound and media devices and check the volume maybe it's very very low or on mute. Also try with other speakers
Posted on Feb 28, 2008
GuruGrundy
  • 64 Answers
SOURCE: Old speakers won't work with new computer! :-(
Trying going into the speakers settings on your integrate sound in control panel and see if you can set it to 5.1 instead of the default 7.1.
Also do you have other speaker to try and plug into the card to make sure the card is installed and working?
Posted on Mar 18, 2009
  • 973 Answers
SOURCE: Dell speakers w/ HP computer - connection failure
Your HP computer may need the Drivers from the Dell Speakers to work properly.
Posted on Jun 19, 2010
Why no sound from my speakers with Dell Dimension 2400, even though it's equipped for sound? Speakers worked fine plugged into Compaq.
Please try other speakers to make sure that it is in fact the computer and not the speaker port itself. If other speakers work, then it is most likely a driver problem. Try to find the drivers for your speakers and install them, restart, and reconnect your speakers. Good luck!
Dec 22, 2010 | Dell Dimension 2400 PC Desktop
Speakers
check ur audio drivers installed correctly or not, then check whether u connected the speakers correctly or not... goto control panel--> sound and audio devices. click that and check whether your sound card drivers are installed or not....
Jul 02, 2009 | Dell Dimension 3000 PC Desktop
Tin like sound from small speakers only. No sound
switch on your speaker set in full volume unplug it from computer touch the plug , as you touch you can hear a sound ( loud hum sound) if the speaker is working. If okay then check the right jack, plug it into green color jack. you can try if your computer is okay use a headphone plug it into the jack in PC , if the computer is okay you may hear the sound.
Jul 01, 2009 | Dell OPTIPLEX 960S Desktop Computer
No sound from rear speakers Creative t6100
Try this:
Go to Control Panel >> Sounds and Audio Devices. Click on Advanced button under Speaker Settings and for Speaker Setup select 5.1 surround sound speakers from the options. Click Apply >> Ok and then check.
Mar 29, 2009 | Creative Labs Inspire T6100 Computer...
Speakers not working.
Try to check with earphones or headphone to anticipate the problem
Mar 26, 2009 | Dell Inspiron 530 Desktop Computer
Mar 18, 2009 | Audio Players & Recorders
Dell GX280 speaker problem..??
Go into the device manager and see if the sound card drivers are installed. If not then you'll need to install the drivers for them.
Feb 06, 2009 | Dell OptiPlex GX280 PC Desktop
HP speakers not working with Dell computer
Your speakers are plugged into the wrong port? Most computers have at least a mic port and a speaker port, many also have front, rear, center, and subwoofer. Try playing a sound, then moving the connector to another port and trying again.
Are your new speakers plugged in? Is the volume on them turned up?
Dec 28, 2008 | E-Machines eMachines Desktop PC
Rear speaker not working
If you did the 5.1 sound test and the rear speaker works, sometimes you have to see in your software speakers settings,probably you need to change to 5.1 speakers
May 28, 2007 | Dell WL6000 Computer Speakers
Dell A525 Computer Speakers Logo
1,375 people viewed this question
Top Dell Audio Players & Recorders Experts
Steve Allison
Steve Allison
ptpumpman
Marvin
Marvin
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
