Question about Pioneer Televison & Video
Pioneer PDP-5010FD (Error Code)
I just purchased a new 5010FD Plasma.  Two problems:  One, tried connecting a Sony Disc Explorer DVD Player (DVP-CX985V) via an HDMI Cable, but couldn't get an image on the screen.  I tried connecting the HDMI connector into a couple of inputs on the monitor, Input 4 and Input 6, but no image would show on the monitor.  Second issue.  Connected a cable box to the monitor via Componet Cables, Input 2.  Worked fine.  Came back after being out of town for one week.  Turned on the cable box, tuned on the monitor.... monitor powered down.  Standby red light blinks 8 times.  Tried unplugging the unit and turning back on after 5-10 minutes same issue.  Disconnected all inputs, sometimes the unit will power up, but anytime I try to connect any inputs the monitor shuts down and the red light blinks 8 times.  Any suggestions on what is causing this issue?  Will a repair fix this or should I push the retailer for a replacement?
  • 4 Answers
SOURCE: pioneer pdp 5080xd
put a pack of smokes direcly in front you wont see the lite anymore
Posted on Dec 14, 2007
donutty
  • 22 Answers
SOURCE: pioneer pdp-v402 40"
http://www.utram.com/medias/Ecrans_Plats/pioneer_PDP-V402_doc_eng.pdf
Posted on Jan 12, 2008
SOURCE: HD Cable Box; HD Plasma...........no picture or sound
Same problem, 42" lg plasma
Posted on Apr 30, 2008
  • 3 Answers
SOURCE: Pioneer PDP-5030HD power supply
click link -ebay shop selling power supply boards for 503hde/pe at 180 pounds you will have to contact him has he does not list them as pioneer are only ment to replace these boards or shops under contract with pioneer i changed mine and only takes min's when you have got the back cover off...
http://stores.ebay.co.uk/Plasma-Parts-UK
hope this helps mark doran
Posted on Mar 17, 2009
SOURCE: 2 year old Pioneer PDP-5070PU plasma TV with red
While not aware of particular problems with this TV (others may know it better) based on the description and my practice with plasmas I'd be inclined to believe that one of the two sustain boards is near end of life.
Could also be problems with the power board, usually caused by dried out capacitors, but could not find reports of that through Google, so my first idea holds.
If you have a screwdriver, muscules to move it around and patience to unscrew all the bolts that hold the back panel you can actually test my theory by disconnecting each sustain in turn and seeing if the TV powers with no problems.
The sustains are the two large boards - one of each side of the display - left and right. Each sustain has a pretty fat power cable connecting it to either the power board or the other sustain (through which it may be getting power).
If I have to guess I'd bet on the Y sustain, which is the larger of the two, usually staying on the left side.
But that's just a guess - could be the other as well.
And, of course, could be just about anything else.
This is just best guess based on experience.
Bobby
http://www.coppelltvrepair.com
Posted on Jan 23, 2010
Hdmi don't work
Contact the authorized service center for Pioneer. Gopakumar Gopalan Google
Jul 23, 2014 | Pioneer PDP-5010FD 50 in. Plasma HDTV
PDP-5010FD FIRMWARE UPDATE
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 24, 2012 | Pioneer PDP-5010FD 50 in. Plasma HDTV
PDP-5010FD FIRMWARE
If you can't see it there, inform me.
How do i do a hard reset on my pioneer pdp-5010
Unplug the TV from AC mains wall socket, and replug it after 10 minutes of so. For more details, download the user manual to this set.
May 08, 2012 | Pioneer PDP-5010FD 50 in. Plasma HDTV
Problem with Pioneer PDP-5080HD 50 in. plasma television The power turns off every 15-20 minutes
hi,
There is some over heating problem in you television. there will be two fans inside you television. if any of the fan get faulty then that section of you TV will get over heated and will shut off by itself preventing from further damages. Check the two fans. For that you have to open your TV.
ok
Jun 07, 2011 | Pioneer PDP-5010FD 50 in. Plasma HDTV
Plasma TV mod PDP-5016HD not turning on
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 27, 2009 | Pioneer PDP-5010FD 50 in. Plasma HDTV
Televison & Video Logo
201 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
