Question about Garden
Need parts for a north star pressure washer vrx2527g
david04928
  • 102 Answers
SOURCE: north star petrol pressure washer.
Sounds like the regulator is sticking or is airbound. loosen the water connection and then tighten it back. Could also be that the trigger gun is faulty or needs adjustment. Hope this helped
Posted on Mar 15, 2009
SOURCE: engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
Posted on Jun 01, 2009
  • 68 Answers
SOURCE: I want to remove the 4gpm pump on my pressure washer.
HI, It sounds like it is just stuck on the keyway as these can be very tight. You need to force the pump of evenly on either side and should come of if patient.
Posted on Feb 08, 2010
Testimonial: "I'm sure the answer is correct. Over time my use of harsh chemicals no doubt corroded the key-way."
heatman101
  • 43501 Answers
SOURCE: I have a M157305J North Star pressure washer. The
The thermostat in the control is sticking... by turning it a bit you get it to release and kick back on...
You need to replace the control...
Heatman101
Posted on Mar 03, 2010
  • 68 Answers
SOURCE: Water does not come out of the lance when I squeeze the trigger
HI it sounds like you may just have a blocked jet on the end of your lance. Please remove and clean.
Posted on Jun 10, 2010
I have a north star pressure washer model 2SFX20ES3 and the pump is not working. The engine is working good. I pull the trigger and no pressure.
Hi
Sometimes you may have to allow a little time for the pump to prime itself and remove the air trapped inside. With the pressure washer at idle and the pressure hose fully extended, squeeze the trigger and see if you get pressure in a couple of minutes.
If you get no joy from that, your pump has likely checked out on you.
Hope this helps.
-Steve
Jun 05, 2015 | Garden
I require a replacement vrx2527g pump. Help
There is a guy on ebay that has almost any matching brand of power washer pumps for sale. I have purchased a new pump from him with no problems and was cheaper than trying to fix old one.
outdoor.concepts is the store.
Oct 26, 2013 | Comet VRX2527G Horizontal Pressure Washer...
My GDX 2525 will not pressurize water. I have tried adjusting the calibration knob on to without success.
It could be that the linkage between the engine and pump is broken. Try the key on the drive shaft. This is a piece of metal that locks the pump shaft and the engine shaft. If it still pumps water the problem probably lies elsewhere.
Jun 08, 2011 | Comet Pump Pressure Washer Pump 2.5 Gpm,...
May 31, 2010 | Northstar Professional Series Pressure...
Heatman101
Mar 03, 2010 | Garden
Feb 05, 2010 | Honda Maxus Prosumer MX5223 Pressure...
No pressure on hose
i have a karcher pressure washer i had to change the fuse box and pressure coils hope this helps .tom
Aug 19, 2009 | North Star Garden
Engine keeps shutting down
May 28, 2009 | Karcher 2500 PSI Pressure Washer
North star petrol pressure washer. working fine, then no high pressure, checked water feed, water filter , pressure relief valve and gun nosall well work sometimes and keep working, when you release the...
Mar 12, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
210 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
